820 2336-a dual cpu tray schematic
  • jair.sharp
    • Jul 2020
    hi everyone a first poster im looking for a schematic for a mac pro 4,1 flashed to a 5,1 dual cpu tay schematic as cpu a blew a fan (replaced whole thing) and im just missing PCEIC and diode temps and heatsink temps and also ram temps on ram slots from 1-4 on the CPU A side and also missing is PCEIC on cpu B but the heatsink and a CPU B are visible
    Many thanks
    Jair
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: 820 2336-a dual cpu tray schematic
    No schematics for Mac Pro.
    I haven't heard of a solution to workaround the compatibility problem in this situation.
    • jair.sharp
      • Jul 2020
      thanks piernov hopefully i see you on pauls next stream just hope somebody might of found a solution or the location of pceic as they seem all linked together
      • andyc
        Intel S2600CP Dual LGA2011 server mainboard schematic wanted
        by andyc
        Hello!
        I found this board in a flea market and it has some torn off components on the back side (smd caps and resistors). Does anyone have a schematic for this beast? I only need the schematic since all the parts are labeled.
        Many thanks!
        01-20-2025, 02:59 PM
      • Byte_76
        Looking for boardview or schematic for Asus Radeon 5500 XT Dual
        by Byte_76
        Hello, I bought a Radeon 5500 XT Dual for very cheap.
        The card is not detected by the PC and the GPU remains cold.
        Using my fingers, I was able to identify that a linear dropout regulator (uP0132Q) and a small component nearby (maybe a resistor) are getting very hot while the rest of the board is cold.
        I get a beep in continuity mode across two caps next to the LDR. Could this be due to a short in the LDR or another nearby commponent? (The caps don't get vey hot)
        I'm trying to figure out whether the LDR is faulty or another component aroud the...
        04-03-2024, 06:10 AM
      • speaktorob
        ASUS RTX 3060 Ti Dual Mini schematic request
        by speaktorob
        I have the boardview as a CAD file (I've shared it in the sticky). But without the schematic I'm blind to figuring out what values any of the components should be showing. Trying to track down a low 1.8V resistance (yes, I'm in denial).
        03-19-2024, 03:29 AM
      • harp
        Metod for removing glued heatsink from fragile component
        by harp
        I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
        06-23-2025, 02:01 PM
      • TinkerTron
        Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
        by TinkerTron
        Hey everyone,
        I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
        Instead, here's what's been bugging me so far:
        The schematic...
        03-06-2025, 02:03 PM
