ASUS GL753VE Schematic NO POWER
  • NConstantinou
    • May 2017
    • 334
    • Cyprus
    does anyone has schematic for Asus GL753VE
    • 20745
    Re: ASUS GL753VE Schematic NO POWER
    Motherboard part number gl753vd ?
    • NConstantinou
      • May 2017
      • 334
      • Cyprus
      pn60NB0DN0-MB2100
        • 20745
        The GL753VD is similar, check the repair guide. https://drive.google.com/file/d/1xuL...Pvam0Bi8j/view
        • NConstantinou
          • May 2017
          • 334
          • Cyprus
          Thanks a lot
          • Sittisac Peou
            • Dec 2021
            Asus GL753ve schematic diagram
            Hell Guys,
            Could somebody help me to get schematic diagram and the component layout for this Asus laptop please.
            I need to fix my laptop, which is missing 1.3V on motherboard.
            Thank you so much
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • meraklinetx
              Asus Z97-a power cycle, no boot no cpu voltage
              by meraklinetx
              Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
              05-10-2023, 06:08 AM
            • Duranitron
              Asus x512dk rev 2.1 power on problem
              by Duranitron
              When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
              Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
              11-26-2024, 10:22 PM
              Asus ROG Strix GL753VD Laptop Schematic / Repair Guide
              Asus ROG Strix GL753VD Laptop Schematic / Repair Guide...
              10-12-2024, 10:52 AM
