Does anyone having Dell Latitude E5420 P16G KRUG 14" UMA A02 10ELT16G001-A schematic or board view files please share .
 Re: Dell Latitude E5420 P16G KRUG 14" UMA A02 10ELT16G001-A schematic
 See if it matches your mb.
 Thanks for quick response. But i already tried with this schematic ,it is different board marking of the parts. I found " Latitude_E5420 KRUG_14_UMA " on a paid website . i will check it.Comment
			by girjamanHi guys,
 I've got an old Dell Latitude E5420 since 2011 and still would like to use it as long as possible. Originally came with i5 cpu, later upgraded to i7-2640M and recently thought to upgrade with quadcore (4/8). Found some reports that it works and some that might not, but said let's do it and ordered an i7-2820QM.
 With i7-2820QM always boots up fine for the first time, OS and all tests run without issues. But after rebooting, it won't boot up anymore. The laptop turns on, power LED is lit and so is the power button. The screen is blank and the fan is not running....-
							Channel: BIOS Requests ONLY!
 03-22-2021, 09:08 AM
			by classicandyHi,
 Please I need location [component number on the board] for FDV301N and 33 ohms Resistor on the PS_ID line for DELL Latitude E5420 [KRUG 14] FOXCONN Build.
 I can't find Schematic for the FOXCONN model of this laptop.
 3v is missing on the PS_ID line at CN87, pin 6 (charging port connector)
 Thanks.
			by diamonI have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
 Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
 Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
 Pictures of these boards:
 Dell Latitude 5520 https://www.ebay.com/itm/256052956663
 Dell Latitude 5530 https://www.ebay.com/itm/125844181534
 Dell...4 Photos
			by berrylinxDell Latitude 7400 2-in-1 bios with absolute persistence lock, Service Tag: HRPJN53
 Can someone please assist with this please. I've provided two dump files using Xgeco T48, one is the read and default saved and other is the Flash saved option, they're labeled according.
 Thank You....-
- Loading...
