MSI thermal 8-m2l4.5 schematic please
  • dachamcse
    • Mar 2018
    • 33
    • Serbia
    Need scheme please
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: MSI thermal 8-m2l4.5 schematic please
    Closest one available
    https://www.badcaps.net/forum/showpo...21&postcount=2
    • dachamcse
      • Mar 2018
      • 33
      • Serbia
      itćs not the same but thanks
      • fightingblind
        • Feb 2020
        So I know this is an old post, but I found that there is another number on this board under the black heat shield on the opposite of the 8-m2l4.5 side of the main board. That number on my board is a match to the link posted above.
        Respectfully,
        Fightingblind
        • Gcnewbie
          Dell Latitude 5570 Ambient thermal sensor reading -127 Degrees C
          by Gcnewbie
          Forgive me this is my first request for help on this forum, so if i've screwed up or not followed the rules i should have i apologise profusely.
          I have a Dell Latitude 5570 that was randomly shutting down, on further investigation i found that the machine had been shutting down due to thermal events as noted by windows event viewer.
          My investigations lead me to the dell diagnostics screen, where i found that there were two sensors out of range which had been causing the shutdowns, one of which was the GPU thermal sensor and the other the ambient sensor.
          I opened the...
          03-29-2024, 06:55 AM
        • Veyron7887
          Laptop overheating after replacement thermal paste
          by Veyron7887
          Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
          11-24-2024, 05:08 AM
        • TinkerTron
          Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
          by TinkerTron
          Hey everyone,
          I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
          Instead, here's what's been bugging me so far:
          The schematic...
          03-06-2025, 02:03 PM
        • atunguyd
          Acer x163w Monitor PSU schematic
          by atunguyd
          Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
          The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
          03-05-2025, 02:08 PM
        • ShadowAi
          ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
          by ShadowAi
          Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
          Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
          After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
          03-15-2024, 10:46 AM
