need schematics NCP81218
  • bakre
    • 105
    • Zwolle
    Hello
    if any one can have a schematic for this ic in a laptop or the
    schematic for this ic but i need the pin out .
    i have seen the schematic from the company but it is not included the pin out.
    the ic number is NCP81218 the laptop is lenovo ideapad 320.
  • anshad
    • Nov 2010
    • 249
    Re: need schematics NCP81218
    Datasheet unavailable but i can help you identifying the pinout
    • bakre
      • 105
      • Zwolle
      thanks soooo much
      could you upload the full schematic please
      Anshad
      • heta1000
        • Jul 2013
        • 33
        • egypt
        thanks
        • fichamba
          • Dec 2011
          • 132
          • Spain
          Thank a lot.
          • shindu41
            • Oct 2016
            • 3
            • Philippines
            hello on this schematic, i have the enable signal vr_on 3.3v but the DRVON is missing , could it be that this ic is faulty?.. can someone help me?
            • F5 NOTEBOOKS
              • Jun 2021
              • 4
              • Brasil
              great
              • BadCapsFriend
                • May 2022
                I have the same question, do you have found an answer?
                • rob77sk
                  • Jun 2020
                  • Slovakia
                  datasheet
                  • supun1992
                    • Jun 2017
                    • 13
                    • Sri lanka
                    same problem?
                    • almirsilvestre
                      • Jun 2020
                      • 40
                      • Brasil
                      Thanks man
                      • victor_quiroga
                        • 62
                        • argentina
                        thanks
                        • cool-oase
                          • Jan 2019
                          • 12
                          Short question,
                          is it fine to replace a NCP81218P with a regualr NCP81218 ?
                          Bought it on AliExpress and the Notebook is still not coming on.
                          In difference to the old IC it just says NCP81218 below the manufactuar logo.
                          Thanks in advance!
                          • Noreddin
                            • Jan 2020
                            • 73
                            • mostaganem
                            thanks
                            • BAKEEL1990
                              • Aug 2020
                              • 19
                              • yemen
                              thanksss
                              • ShadowAi
                                ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                                by ShadowAi
                                Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                                Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                                After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                                03-15-2024, 10:46 AM
                              • TinkerTron
                                Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                by TinkerTron
                                Hey everyone,
                                I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                Instead, here's what's been bugging me so far:
                                The schematic...
                                03-06-2025, 02:03 PM
                              • atunguyd
                                Acer x163w Monitor PSU schematic
                                by atunguyd
                                Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                                The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                                03-05-2025, 02:08 PM
                              • Thetechdude
                                MSI Ventus RTX 4080 16G Broadview schematic needed
                                by Thetechdude
                                Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
                                I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
                                Thanks.
                                07-15-2025, 11:15 AM
                              • ianpoultonknights
                                Zenbook Flip 15 UX562AI schematic
                                by ianpoultonknights
                                Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
                                06-26-2025, 02:41 PM
