hi need help schematic la-c503p
  • jesi
    • Jul 2013
    • 78
    hi
    need help on la-c503p info on ic pu801 ??????
  • imranromi
    • Jan 2015
    • 1290
    • Pakistan
    Re: hi need help schematic la-c503p
    Originally posted by jesi
    hi
    Only have pics..
    • jesi
      • Jul 2013
      • 78
      your the best
      many thanks
      • jesi
        • Jul 2013
        • 78
        no schematic , what about kb9022 need 2 of them
        • jesi
          • Jul 2013
          • 78
          do you have schematic and any kb9022 ????
          • mberbouch
            • May 2014
            • 109
            • Morocco
            Originally posted by imranromi
            Only have pics..
            Thanks friend.
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3627
              • slovakia
              Only have pics..
              on that pic u see burned place, just like mine. anybody know why?
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3627
                • slovakia
                still no schem for this guy guys?
                • salawayon
                  • Nov 2012
                  • 578
                  • philippines
                  Only have pics..
                  based on your pics and still no available schematics, someone could ID the component U1? got same unit with burned U1 component.
                  sorry if i replied or posted on this thread...
                  thanks...
                  • ismaelstepheno
                    • Jun 2020
                    • 231
                    • UE
                    NL17SZ74USG VFSOP-8
                    • ismaelstepheno
                      • Jun 2020
                      • 231
                      • UE
                      this one can help you
                      Badcaps Electronics Repair Forum & Part Search
                      • Doniciputat
                        • Aug 2022
                        • 111
                        • Indonesia
                        thankyou ser
                        • TinkerTron
                          Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                          by TinkerTron
                          Hey everyone,
                          I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                          Instead, here's what's been bugging me so far:
                          The schematic...
                          03-06-2025, 02:03 PM
                        • atunguyd
                          Acer x163w Monitor PSU schematic
                          by atunguyd
                          Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                          The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                          03-05-2025, 02:08 PM
                        • Thetechdude
                          MSI Ventus RTX 4080 16G Broadview schematic needed
                          by Thetechdude
                          Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
                          I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
                          Thanks.
                          07-15-2025, 11:15 AM
                        • ianpoultonknights
                          Zenbook Flip 15 UX562AI schematic
                          by ianpoultonknights
                          Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
                          06-26-2025, 02:41 PM
                        • Adv10119
                          Need help please! schematic for LA-9982P rev 3.0 (A02)
                          by Adv10119
                          Please help, i need schematic diagram for Dell inspiron 3537 board LA-9982P rev 3.0 (A02). Specific for A02.
                          I have a one beep with no display problem. Did reprogrammed the bios but no luck. i tried to troubleshoot using rev 3.0 (A08) version schematic and boardview but there's components/rails in the schematic that is none in my actual board, this is why I'm having problem checking every power rail needed if ok. attached is the photo of my actual board.
                          I'm not sure if A02 and A08 is really different schematic version from each other, but I have to try....
                          01-31-2024, 01:18 AM
