Macbook Pro A1707 - 820-00928-04
  • thedirtylurker
    • Oct 2018
    • canada
    I've been searching but I still haven't found the schematic or board view files for 820-00928-04 / 829-00928-A
    Has anyone the files for this one yet?
  • MobileXT
    • Oct 2012
    • 202
    Re: Macbook Pro A1707 - 820-00928-04
    Did you get it already? I also looking for this one 820-00928. Thanks
    • Mojotechie
      • Oct 2018
      • 5
      • usa
      I am also in need of finding this as well.
      • piernov
        • Jan 2016
        • 4436
        • France
        Use 820-00281.
        • dutcahtech
          • Jun 2018
          • Indonesia
          i owe a lot to this forum.. Its time to payback..
          https://drive.google.com/file/d/16gw...ew?usp=sharing
          unfortunately i dont have the schematics in PDF.
          If anyone has it kindly share please..
          Thank you..
          • sgaiduk
            • Jan 2019
            • Russia
            Hi to all, many thanks @dutcahtech for the board file
            Probably someone have pdf file too?
            or please can you check Q6000 MOSFET part number, is it DMN32D2LFB4-7?
            • piernov
              • Jan 2016
              • 4436
              • France
              Read post #4.
              • guzq
                • May 2017
                • 54
                • Indonesia
                Thank you..
                Thanks Man
                • auctec
                  • Sep 2020
                  • 5
                  Check these
                  • dr.soil
                    • Oct 2019
                    • fiji
                    schematic in pdf
                    • leonemax81
                      Macbook a1707 820-00281 Battery no Power
                      by leonemax81
                      Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
                      08-23-2024, 09:24 AM
                    • sofles
                      Macbook a1707 2017 model 820-00928 GPU issue
                      by sofles
                      Hello there
                      I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                      I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                      11-21-2024, 05:25 AM
                    • tommy97
                      Apple MacBook A1707 No Audio/Sound
                      by tommy97
                      I'm having an issue with an A1707 MacBook Pro—there's no audio output. Initially, the MacBook came in with a no-power problem, and I found a faulty U6400, which I've now replaced. The laptop now powers on, but there's still no sound.
                      I've also replaced U6300, but the problem persists.
                      Here are the current voltage readings:
                      • PPV18_S0: 1.8V
                      • R6402: 1V
                      • R6405: 1V
                      • R6403: 1V
                      • AUD_SPKRAMP_RESET_L: 1.3V
                      • PPBUS: 12.6V
                      03-10-2025, 11:22 AM
                    • Cemal Odabasioglu
                      MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                      by Cemal Odabasioglu
                      I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                      Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                      Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                      Observations...
                      01-14-2025, 03:54 PM
                    • Herby94
                      MacBook Pro A1707 Won’t Boot – No Display, Fans Spin Briefly
                      by Herby94
                      I’m currently having an issue with my MacBook Pro (A1707). It doesn’t power on or make any sounds.
                      • The charger is a generic third-party unit that had a loose connection at the AC input (127VAC). I fixed it, and now it delivers 20VDC to the laptop.
                      • When connected, the fans spin for about 30 seconds before shutting off.
                      • No display, no audio, and no signs of life during this time.
                      Any ideas? Could this be a logic board issue, or is the charger still a problem? Thanks in advance!...
                      08-07-2025, 08:59 AM
