HP 15 | BDL50 LA-D703P Boardview || Schematic
  • master3239
    • Nov 2021
    • Russia
    Re: HP 15 | BDL50 LA-D703P Boardview || Schematic
    does anyone have the same board view file please help
    • kher
      • Jan 2021
      • 16
      • philippines
      boardview plz
      • Stranged
        • Apr 2021
        • 6
        • South Africa
        check if you have 5v and 3.3v if not trace 3v awls pin 6 of the buck converter
        • josemaaaaaa
          • Apr 2017
          • Spain
          Originally posted by mafiaxxx
          try this
          Thanks.
          • Gonzalo Rayel
            • Aug 2021
            • Argentina
            BDL50 LA-D703P Boardview please!
            • MrMike0498
              • Aug 2023
              • México
              #26
              Hi i have a short in 3VALW, when i inject 3v to 2amp the processor turns hot, i cant understand if there is the problem
              i have short in jumpers J1, PJP2, PJB4 PJP9, PJP10 and PJM4
              my board is bdl50 la-d704p rev 4.0 and im amateur
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                #27
                If you want further help beyond a bios request start a new thread here:
                https://www.badcaps.net/forum/forumdisplay.php?f=23
                Give as many details as possible about the voltage, resistance tests you've done so far.
                Become a Badcaps supporter
                Thanks to all supporters.​
                • 10r
                  • Aug 2023
                  • india
                  #28
                  Can anyone please share hp bdl50 la-d703p rev 3.0 boardview
                  • vpha
                    • Dec 2013
                    • 17
                    • India
                    #29
                    Can someone please tell me where UC3 is located?]
                    • mard312
                      Legion Go 8APU1 boardview or schematic
                      by mard312
                      I’m working on repairing a Lenovo Legion Go that suffered liquid damage. Unfortunately, one of the ICs on the motherboard burned out, and I haven’t been able to find any boardview or schematic for this model anywhere.
                      Does anyone happen to know what this particular chip is, or have access to the schematic/boardview for this motherboard? Any help or reference would be greatly appreciated.
                      11-12-2025, 01:01 PM
                    • AustinCER
                      In Search of Schematic/Boardview for Lenovo Ideapad Flex 5 14ALC7
                      by AustinCER
                      I am in search of a schematic or boardview for Lenovo Ideapad Flex 5 14ALC7.
                      No power and no charging LED with AC Adapter connected. AC Adapter is functioning at 19V, and also tried another Lenovo AC Adapter -- no charging LED still.
                      There is an active 19V from the USB-C port to the motherboard with AC Adapter connected, so the port is also fine. I am assuming there is a short on one of the power rails, but don't know where to start looking.
                      Any insight, schematic or boardview would be greatly appreciated.
                      Model: Lenovo Ideapad Flex 5 14ALC7...
                      11-04-2025, 03:49 PM
                    • PacoGT
                      HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
                      by PacoGT
                      hello firends
                      i search the schematic or boardview
                      I have this motherboard, but I can't find the schematic or the boardview.
                      The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
                      So the computer doesn't turn on, and the 3V disappears after a few seconds.
                      The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
                      The new problem arose after removing the bad chip.
                      3V and 5V remained together,...
                      08-19-2025, 08:25 PM
                    • hosain0489
                      Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
                      by hosain0489
                      I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
                      Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
                      If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
                      Thank you very much in advance!
                      07-15-2025, 11:20 AM
                    • re-atari
                      Gigabyte GA-H110-D3A schematic/boardview needed
                      by re-atari
                      Hello all,
                      Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
                      This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
                      02-24-2025, 06:45 PM
