Lenovo 120S no backlight. Schematic needed
  • claudyu07
    Claudyu07
    • May 2014
    • 164
    • Ireland
    hi guys.
    Lenovo 120s no backlight after someone tried to change lcd without disconnecting battery.
    I have checked for fuse around lcd connector but can't find any.
    Motherboard 120s_mb_v1.0 svt.
  • claudyu07
    Claudyu07
    • May 2014
    • 164
    • Ireland
    Re: Lenovo 120S no backlight. Schematic needed
    Anyone pls? Is fairly urgent.
    • MJ-meo-dmt
      • May 2016
      • 186
      • South Africa
      Hi.
      Are you getting all the voltages for the LVDS out. 3.3V, B+...
      Did you check with a new LED/LCD? or check the/for fuse on the LED/LCD driver board(the one on the screen)...
      Check the cable sometimes they burn a wire or 10... :P
      If its a eDP setup like on the Dell's check the LED Driver chip / and or power circuit for it... (had a bad time with a xps)
      while alive { live(toFullest=true) }
      • zurvanielle
        • Feb 2017
        • 137
        • Philippines
        i also need the schematic diagram of this motherboard 120S_MB_V1.0 SVT.. plz share...^_~
        • crowntoy99
          • Oct 2012
          • 264
          • india
          Originally posted by claudyu07
          hi guys.
          hai bro
          you have a bios file
          • Duranitron
            • Jul 2014
            • 544
            • Philippines
            just a suggestion try another good lcd screen. try to increase brightness in keyboard shortcut usually f keys.
            • ca3cooh
              • Sep 2018
              • 17
              • Indonesia
              here it is bios and everything
              https://www.badcaps.net/forum/showthread.php?t=83026
