MSI GE72 2QC Schematic plz
  • medinfo
    • May 2016
    • 328
    • Morocco
  • cdwayne foremost
    • Mar 2015
    • 20
    • jamaica
    Re: MSI GE72 2QC Schematic plz
    not release as yet
      • 20855
      Its available on some paid sites. MS-16J2/1792
      • piernov
        • Jan 2016
        • 4435
        • France
        Dunno if it's close enough.
          • 20855
          I found it .
          • Krilan1990
            • Jan 2023
            • 37
            • Poland
            Hello, I am looking for a schematic for msi ge62 2qd (ms-16j21 ver.1.0 in version 4.5mb). i will be grateful for any help.
              • 20855
              Is there anything wrong with the Rev 1.0 schematic posted above. Why does it have to be 4.5MB
              • AL._.EX
                • Dec 2022
                • 863
                • Belarus
                4.5 Mb - or there was some other assembly rev1.0 or there were watermarks on the pdf. I haven't seen any other differences.
                • Krilan1990
                  • Jan 2023
                  • 37
                  • Poland
                  I'm not sure if the schematic is complete or if there are some gaps in the pages. I saw that there is a diagram on vinafix but it takes up more space so I am asking if anyone has such a file and can upload it to the forum
                  • Krilan1990
                    • Jan 2023
                    • 37
                    • Poland
                    In my laptop there was a damage to the usb2.0 socket, after initial measurements it turned out that between the mass and the date - there is 10 ohms and between the date + and the mass is about 60 kohm. there is also a high impedance between vcc (5V and ground. The laptop is msi ge62 2qd motherboard ms16j21 ver1.0. is it possible that there is some element between the bridge and usb that could be damaged and ground date-. I found a diagram on the vinafix website but it is a bit too expensive for me to download it. and the free versions of the schematics may not be complete. generally the laptop works fine, the temperatures oscillate between 40-50 degrees and the other components work. Please advise what could be done with it, how to save these usb and is it profitable and how much can it cost.Thanks in advance for all suggestions
                    • AL._.EX
                      • Dec 2022
                      • 863
                      • Belarus
                      Krilan1990, Write the name of the faulty connector (UCB CON1 - CON3).
                      • Krilan1990
                        • Jan 2023
                        • 37
                        • Poland
                        usb 2.0 , this laptop has only one usb 2.0 port, next to the sd card slot and the power adapter port
                        • AL._.EX
                          • Dec 2022
                          • 863
                          • Belarus
                          Subboard 116J12-1
                          USB1: problems - U2 with strapping, EL1, FPC1. Motherboard - FPC1, HUB.
                            • 20855
                            USB chart on page 28
                            • Krilan1990
                              • Jan 2023
                              • 37
                              • Poland
                              thank you i found it. but I do not know if this socket has a system between the bridge that could be damaged?? did he break the bridge?
                              • Krilan1990
                                • Jan 2023
                                • 37
                                • Poland
                                after connecting the mouse, the computer does not see the device, it does not recognize it. when I measure the signal pins with a multimeter, on the data pins I have 60kohm and 10 ohm. as one pin was shorted to ground. I do not know if there is a pullup resistor or some esd element between the socket and the bridge, there is no burn mark on the board and the computer works normally. only the usb2.0 port does not work.
                                • AL._.EX
                                  • Dec 2022
                                  • 863
                                  • Belarus
                                  Disconnect the cable from USB1 and measure signals directly on FPC1 motherboard. They go directly to the HUB.
                                  • Krilan1990
                                    • Jan 2023
                                    • 37
                                    • Poland
                                    I can't find boardview anywhere
                                    • Krilan1990
                                      • Jan 2023
                                      • 37
                                      • Poland
                                      I measured on a turned off laptop. when the 16j12 board is disconnected, it is out of range and when I connect the tape to the motherboard and measure on the pins, it has this value
                                      • Krilan1990
                                        • Jan 2023
                                        • 37
                                        • Poland
                                        what is this signal fpc1
                                        • TinkerTron
                                          Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                          by TinkerTron
                                          Hey everyone,
                                          I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                          Instead, here's what's been bugging me so far:
                                          The schematic...
                                          03-06-2025, 02:03 PM
                                        • atunguyd
                                          Acer x163w Monitor PSU schematic
                                          by atunguyd
                                          Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                                          The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                                          03-05-2025, 02:08 PM
                                        • Thetechdude
                                          MSI Ventus RTX 4080 16G Broadview schematic needed
                                          by Thetechdude
                                          Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
                                          I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
                                          Thanks.
                                          07-15-2025, 11:15 AM
                                        • ianpoultonknights
                                          Zenbook Flip 15 UX562AI schematic
                                          by ianpoultonknights
                                          Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
                                          06-26-2025, 02:41 PM
                                        • Much Bugs
                                          MSI Z390 A-PRO Schematic and BoardView
                                          by Much Bugs
                                          The Schematic and BoardView( *.cad ) of MSI Z390 A-PRO , the board model no is MS-7B98 Rev1.0-1.1 ....
                                          06-24-2025, 10:13 AM
