MSI GE72 2QC Schematic plz
    • 21936
    Re: MSI GE72 2QC Schematic plz
    Originally posted by Krilan1990
    what is this signal fpc1
    Where are you looking,on what page,FPC1 is the name of the connector .Flexible Printed Circuit (FPC) Connectors
    • AL._.EX
      • Dec 2022
      • 896
      • Belarus
      Sorry everyone for not english).
      Пан, тут вельмi проста и робiцца усё без схемы i борда. Мультiметр для чаго? Становiшся на USB1 i глядiш якiя сiгналы адпавядаюць яму на FPS1. Потым вымяраеш гэтыя сiгналы с адключаным шлейфам.
      Ну прасцей не бывае ). 99,9% вiнаваты будзе HUB ).
      • AL._.EX
        • Dec 2022
        • 896
        • Belarus
        Sorry again for not English, but such damage is in a couple of minutes.
        • Krilan1990
          • Jan 2023
          • 37
          • Poland
          I don't quite understand what FPc1 is.
          • Krilan1990
            • Jan 2023
            • 37
            • Poland
            I measured on the ribbon connector on the motherboard, the results are the same
            • Krilan1990
              • Jan 2023
              • 37
              • Poland
              #26
              At the beginning, I connected the ground probe and measured all the pins in turn. Only Pin DATE- has low impedance. This damage is on the motherboard but I don't know what could be damaged. is the bridge or is there a system in front of the bridge that protects the bridge has been damaged.
              • AL._.EX
                • Dec 2022
                • 896
                • Belarus
                #27
                If the cable was disconnected at the same time - the USB2.0 HUB port is damaged (.
                • Krilan1990
                  • Jan 2023
                  • 37
                  • Poland
                  #28
                  port or bridge??
                  • Krilan1990
                    • Jan 2023
                    • 37
                    • Poland
                    #29
                    only replacing the bridge will fix it usb??
                    • Krilan1990
                      • Jan 2023
                      • 37
                      • Poland
                      #30
                      the diagram does not show any elements between the bridge and the usb2.0 port that may have been damaged.
                      • Krilan1990
                        • Jan 2023
                        • 37
                        • Poland
                        #31
                        I didn't even see the esd chip
                        • AL._.EX
                          • Dec 2022
                          • 896
                          • Belarus
                          #32
                          There is no protection there.
                          • Krilan1990
                            • Jan 2023
                            • 37
                            • Poland
                            #33
                            is the bridge broken?
                            • Krilan1990
                              • Jan 2023
                              • 37
                              • Poland
                              #34
                              only replacing the bridge will help??
                              • AL._.EX
                                • Dec 2022
                                • 896
                                • Belarus
                                #35
                                Just change the bridge. What did you bind to this port? Are the others working for you? If yes, then leave him alone.
                                • Krilan1990
                                  • Jan 2023
                                  • 37
                                  • Poland
                                  #36
                                  replacement of the bridge may not be economical. laptop for almost 8 years
                                  • Krilan1990
                                    • Jan 2023
                                    • 37
                                    • Poland
                                    #37
                                    maybe someone on the forum has schematics from the vinafix website and could share
                                    • AL._.EX
                                      • Dec 2022
                                      • 896
                                      • Belarus
                                      #38
                                      Leave your laptop alone - magic won't help).
                                      • AL._.EX
                                        • Dec 2022
                                        • 896
                                        • Belarus
                                        #39
                                        Give a link to Vinafix.
                                        • Krilan1990
                                          • Jan 2023
                                          • 37
                                          • Poland
                                          #40
                                          I can't post a link to the page
                                          • TinkerTron
                                            Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                            by TinkerTron
                                            Hey everyone,
                                            I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                            Instead, here's what's been bugging me so far:
                                            The schematic...
                                            03-06-2025, 02:03 PM
                                          • atunguyd
                                            Acer x163w Monitor PSU schematic
                                            by atunguyd
                                            Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                                            The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                                            03-05-2025, 02:08 PM
                                          • Thetechdude
                                            MSI Ventus RTX 4080 16G Broadview schematic needed
                                            by Thetechdude
                                            Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
                                            I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
                                            Thanks.
                                            07-15-2025, 11:15 AM
                                          • ianpoultonknights
                                            Zenbook Flip 15 UX562AI schematic
                                            by ianpoultonknights
                                            Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
                                            06-26-2025, 02:41 PM
                                            MSI Gaming GE72 2QC-014NL Apache Notebook GE Specification for Upgrade or Repair
                                            This specification for the MSI Gaming GE72 2QC-014NL Apache Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GE72 2QC-014NL Apache boardview and GE72 2QC-014NL Apache schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 07:29 AM
