HP dv6 Envy (Goya/Balen 1.0 DDR3 11254-3)
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Hello i have this HP that wont turn on with AC adapter, but if i insert battery when AC adapter is connected the laptop will start by itself.
    Anyone have schematics? Or have idea what can be problem?
    Model: dv6-7275ez
    MB: Goya/Balen 1.0-DDR3 11254-3 48.4ST10.031
    ...the quieter you become the more you are able to hear...
  • bachir2004
    • Feb 2015
    • 437
    • maroc
    Re: HP dv6 Envy (Goya/Balen 1.0 DDR3 11254-3)
    i hope this is what you need.not sure.
    • rtstorm
      • Feb 2012
      • 971
      • Croatia
      Thank you, i really need boarview for this board - cannot find many components on board (no label) i see that other web sites are selling, any one of you guys have it?
      • rtstorm
        • Feb 2012
        • 971
        • Croatia
        hey i found board view, here it is if someone need it.
        Can you help me, what voltage i shoud have on DC_PIN1, DC_PIN2, LIMIT_SIGNAL and AD_JK
        i only have 19V on DC_PIN1, DC_PIN2 and LIMIT_SIGNAL
        AD_JK is 0V
        • piernov
          • Jan 2016
          • 4435
          • France
          The connector's pinout table is on the left on your picture.
          You should have 19V coming from power brick on pin 8/9/10.
          Pin 1 should show a couple of volts when adapter is plugged it, and pin 2 should show a couple of volts when the battery is charging.
          Pin 3 is the power brick identification pin, voltage will depend on the power rating of the power brick, but might be a couple of volts too.
          You may have reversed the pin numbering, check that again, and check that the cable is plugged in the correct way.
          • rtstorm
            • Feb 2012
            • 971
            • Croatia
            hello, i check voltage
            pin 1 - 0V
            pin 2 - 0.45V
            pin 3- 0.61V
            pin 4,5,6 - 0V (GND)
            pin 8,9,10 - 19V
            i tested this only with AC adapter (no battery)
            • rtstorm
              • Feb 2012
              • 971
              • Croatia
              but i think schematic is no good, on my board PU3802 is not populated, also PR3807, PQ3802 so i think it is some different circuit
              • bilen
                • Aug 2014
                • 632
                • istanbul
                hi .
                Did you solve the problem?
                I have the same fault ....
                • fharlock999
                  • Nov 2017
                  • 61
                  • Chile
                  thanks!
                  • charafmak77
                    • Oct 2017
                    • 81
                    • jijel
                    thanks
                    • coelectron
                      • Mar 2014
                      • 58
                      • Argentina
                      thanks
                      • martinbalou72
                        • Feb 2020
                        • france
                        do you have the solution please?
                        • Techtiger
                          • Oct 2014
                          • 1601
                          • france
                          Open a new thread and you have to come up with some measurements
                          • lapzlapz
                            • May 2016
                            • 20
                            • kerala
                            11254-2 schematic diagram available ?? Guys
                            • redman13
                              • Aug 2016
                              • 66
                              • bangkok
                              Thang you
                              • victor_quiroga
                                • 61
                                • argentina
                                thanks!
