HP Envy DV6 Goya-Balen 1.0-DDR3 Bios file repair
  • salawayon
    • Nov 2012
    • 575
    • philippines
    Goya-Balen 1.0-DDR3.
    no display problem with this one. i attached my backup.
    thanks..
    • 21204
    Re: HP Envy DV6 Bios file repair
    Use a hex editor to find the BID - https://www.badcaps.net/forum/showpo...9&postcount=40 (see both pictures, BID and DMI offsets)
    https://www.badcaps.net/forum/showthread.php?t=54376
    Yours is the same as that one, BID01818 .Use the bios at post #24 and copy the DMI using the offsets in the picture from your backup to the new bios.
    • salawayon
      • Nov 2012
      • 575
      • philippines
      thank you very much for the tutorial... it works...
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • Forest79
        by Forest79
        07-23-2023, 07:39 AM
      • maanee11
        Help to get Lenovo BIOS bin file for Thinkpad T560
        by maanee11
        Hello Everyone,
        I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
        https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
        In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
        05-15-2022, 11:59 AM
      • Sebastian Codrean
        BIOS file for ASUS F542UN laptop
        by Sebastian Codrean
        Hello to all of you! I need help with a BIOS file.
        The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
        So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
        02-20-2025, 10:25 AM
      • Fr33man
        BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
        by Fr33man
        I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
        *Novo button power on
        *Disconnected internal battery...
        09-23-2024, 01:16 PM
