2015 macbook pro 820-00426-A
  • reverendalc
    • Jul 2016
    • 81
    hello all! i hope somebody may be able to share a schematic/brd for:
    2015 MacBook Pro A1398 EMC2910
    820-00426-A
    i would be much obliged
    This isn't Monaco... This is Baghdad
  • MobileXT
    • Oct 2012
    • 214
    Re: 2015 macbook pro
    not available at the moment used 820-00138 or the 820-3787.
    • Raiko I
      • Feb 2018
      • 6
      • Cuba
      The 820-00163 works for my problem
      • twonk9098
        Macbook Pro mid 2015 battery required to boot?
        by twonk9098
        I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
        The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
        This model has the newer trackpad which is not clickable when turned off.
        At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
        If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but...
        12-10-2024, 06:51 PM
      • pippo_one
        Macbook a1398 emc2910 820-00426A
        by pippo_one
        Hi everyone, I have a MacBook a1398 emc2910 with an 820-00426A motherboard.
        I have a short on the "PPBUS_G3H" line... I traced it to the "U7310" IC
        FDMF6808N"
        and indeed the IC is shorted between "Vin and VSWH."
        On the motherboard, Vin to ground = open and it's OK.
        VSWH to ground = about 5,50 / 7.50 Ohms.
        With this measured value, can I safely replace this IC or is the CPU compromised?
        Do you have any other suggestions?
        Thanks for any help you can give me.
        07-20-2025, 03:35 AM
      • envym
        by envym
        Hi everyone!
        06-27-2025, 08:54 AM
      • yura8
        Need BIOS/EFI dump for MacBook Air A1466 2015 EMC 2925 (8gb)
        by yura8
        Hi there! I have not so usual situation...
        I have 2015 MacBook Air A1466 EMC 2925 with 8Gb of RAM. It seams that I've killed it by bad SSD adapter. It starts, cooler works... But no chime, screen is black. SMC reset seams works, NVRAM reset doesnt works...
        My repair guy has checked all possible. It's all ok with power. The last idea - I could kill EFI firmware... So, I need a firmware of EFI to check it. I have a programmer. But I don't have a similar laptop now to download it and compare
        P.S. If you have else any ideas about repair, or you had a similar...
        12-20-2024, 02:31 PM
        Apple MacBook Pro 15 Retina A1398 EMC2910 820-00426 Boardview
        Apple MacBook Pro 15 Retina A1398 EMC2910 820-00426 Boardview...
        10-26-2024, 04:08 AM
