i need schematic asus k55de rev2.0..pls help..
schematic needed asus k55n(no power)
Tags: None
Re: schematic needed asus k55n(no power)
there is only RG for this unit , o power issues on asus are related to bad DC IN mosfets , or somethimes bios issues .
so im gonna send you both , Repair Guide and Bios
let us know
sending bios , repair guide and boardview
best of luckAttached Files -
i have the same problem.. my charger test ok but on the first 5 volt rail in his pic..witch is r8824 i get a rolling number so i took r8824 off and same thing i checked for short to ground and i get 840 any help would be great thanksComment
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
Assuming...7 Photos -
Hi.
Long shot but does anyone have a schematic & boardview for the audio board+power button on a Macbook A2179?
There is a shorted cap on mine and I need to know if I can safely remove it or whether I need to replace it and with what capacitor.
Many thanks. ...-
08-21-2025, 02:38 PM -
by meraklinetxHello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
by ShadowAiHello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,... - Loading...
