Asus X550LN NO Power
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Hey guys, trying to solve this problem, laptop doesn't have any 3.3 and 5 Volts.
    Anyone with schematic or boardview ?
  • subroto
    • Oct 2015
    • 230
    • Bangladesh
    Re: Asus X550LN NO Power
    Bro. please mention mobo model no.
    • passete
      Living=Sharing
      • Jun 2015
      • 487
      • France
      I was able to boot the pc after i had the ideao of charging the battery on another Asus laptop.
      Now this is the problem i have, found the exact problem on another forum:
      with battery inserted, the laptop turns on if the battery has enough charge
      the windows 8 (64bit) shows "plugged in, charging" with the taskbar icon showing the battery charging icons for a short bit
      after about 30 secs or so, it goes back to a solid battery icon (without the charge level animation)
      All this while the battery is actually not getting charged. It is actually discharging.
      If i unplug the ac adapter and plug it back in, it shows that animation for a few more seconds again before going back to solid, non-animation icon. It is still saying "plugged in, charging"
      The battery is working fine on another Laptop, charge and discharge normaly.
      Motherboard is : X550LD REV.2
      Help Please
      • passete
        Living=Sharing
        • Jun 2015
        • 487
        • France
        Please ,need boardview or schematic
        • kotnatan
          Banned
          • Apr 2014
          • 181
          • Ukraine
          http://**************/load/noutbuki/.../313-1-0-43290
          http://**************/load/noutbuki/.../313-1-0-39206
          http://**************/load/noutbuki/.../313-1-0-35775
          • passete
            Living=Sharing
            • Jun 2015
            • 487
            • France
            Thanks, but i can't download the file.
            can you post it here, or send me a email please ?
            • passete
              Living=Sharing
              • Jun 2015
              • 487
              • France
              Can anyone download the above files and post them ?
              • passete
                Living=Sharing
                • Jun 2015
                • 487
                • France
                Please, need schematic or boardview for Asus X550LN
                Anyone ?
                • fox01fox02
                  • Oct 2015
                  • 28
                  • iran
                  Anyone ?
                  hi my friend
                  boardview + repair guide
                  Good luck
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                  • PantherDave
                    by PantherDave
                    Hi all!
                    I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. πŸ˜…
                    05-29-2024, 02:01 PM
                  • ShadowAi
                    ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                    by ShadowAi
                    Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                    Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                    After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                    03-15-2024, 10:46 AM
                  • meraklinetx
                    Asus Z97-a power cycle, no boot no cpu voltage
                    by meraklinetx
                    Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                    05-10-2023, 06:08 AM
                  • conghuyms
                    Request for Help – ASUS G531GW Rev 1.6 – No Power On
                    by conghuyms
                    I need your support with an ASUS G531GW Rev 1.6 laptop.
                    When I plug in the charger, the battery charging LED turns on, but the board does not power on when pressing the power button.
                    Here’s what I’ve checked so far:
                    • Motherboard has been removed for inspection.
                    • 3V and 5V always-on rails are present (3V/5V_ALW).
                    • 1.8V and 1.09V at the PCH are present.
                    • I don’t have the boardview/schematic, so troubleshooting is limited.
                    • I tried checking the power button signal from the
                    07-20-2025, 09:14 PM
