Compal LA-C341P - A4WAB Acer E5-473 - Schematic
  • dexx
    • Dec 2013
    • 18
    • Philippines
    Re: Compal LA-C341P - A4WAB Acer E5-473 - Schematic
    didn't worked for me the status of the laptop is when i power it on it will turn on for a few seconds then just as you will notice that the lcd will display it will lose all power then turn on again automatically, i've already check the motherboard for faulty or shorted ic and capacitors but found none .. so my last option was this to reprogram the ic but didn't work
    do you have any idea what i can try next?
    • techman1025
      • Jun 2014
      • 497
      Hi
      Ok let's start from the beginning is my file doing exactly the same as yours any differents ?
      What os is on this model 8 or 10. When it does start do you have any activity on usb ports like if you plug a mouse or keyboard in does it light up for a min ?
      Techman1025
      • moophus
        • Feb 2017
        • 12
        • England
        I received my programmer today... should I try flashing bios first or the EC? which one is more likely to corrupt?
        (I'm getting no power led on DC-In - logically what controls the power led? i would think the EC)
        • techman1025
          • Jun 2014
          • 497
          Hi
          Is this a two chip board? if only one chip it's all togetter 8MB .. I would then upload back up firmware here and i will look at it and give you a working file back..
          Techman1025
          • fddizon
            • Sep 2011
            • 555
            • Philippines
            here is mine techman
            SNID 54500798334
            TIA
            • whaldsz
              • Apr 2013
              • 395
              • Philippines
              #26
              SNID 54500798334
              TIA
              what's the problem with your laptop?
              • fddizon
                • Sep 2011
                • 555
                • Philippines
                #27
                Sir Whaldsz,
                No display
                standby current mobo with ram and bin proc .001 amps
                stops at .488 up and down a bit
                fainted screen flickers but no display even using a flashlight
                mild reflow was made to gpu chip to no avail
                • moophus
                  • Feb 2017
                  • 12
                  • England
                  #28
                  Oh My.
                  After flashing the KB9022 with my new RT809F flasher, I got LIGHTS!! woohoo!
                  but then, I had messed with one of the SMD DC to DC chips (EM5209VF) when I was poking around looking for shorts so I had to wait another two weeks for that chip to arrive from china (the only place I could find it online)
                  Just soldered it on... and now she boots!! This was my first board repair....I'm so proud of myself!! My two new shiny tools actually paid off, the RT809F flasher and my hot air rework station.
                  TLDR - EC got corrupted - needed a reflash. Being a newb and didn't know this, destroyed a DC power chip and had to replace and also reflash to get computer working
                  • mitu_sharma
                    • Jul 2015
                    • 182
                    • india
                    #29
                    thank you so much friends
                    • mcoytzhi27
                      Mr
                      • Nov 2015
                      • 43
                      • philippines
                      #30
                      here
                      • gerardo
                        Engineer
                        • Feb 2016
                        • 59
                        • Argentina
                        #31
                        Thanks!
                        • burnnet2
                          • Feb 2014
                          • philippines
                          #32
                          hi guys..i have a e5-473g laptop..the problem is intermittent power after 6 sec. will shut off the light..i flash the bios and reheat video chip and procie..same problem..whats the best solution..i have 3 unit encountered the problem..thanks in advance..
                          • lorins_core
                            BlackSmith
                            • Dec 2012
                            • 552
                            • Philippines
                            #33
                            that everyone there. already flash the EC for this unit Used RT809F. can you teach me how. I already Flash the SPI Rom. Same as Problem.
                            • kenttech16
                              • Oct 2011
                              • 27
                              • Philippines
                              #34
                              Hello Guyz!
                              Nice to be back again after so long.
                              I have a problem with this model also even tried reheating the gpu and running bios crisis but to no avail.
                              So it means flashing the bios and EC might have a higher rate of success. Need to get RT809F flasher as what moophus did.
                              Thanks..
                              • HarryPK
                                • Mar 2014
                                • 212
                                • barabai
                                #35
                                Any working biis please...
                                • HarryPK
                                  • Mar 2014
                                  • 212
                                  • barabai
                                  #36
                                  I have 8mb single bios...
                                  • HarryPK
                                    • Mar 2014
                                    • 212
                                    • barabai
                                    #37
                                    Sir Whaldsz,
                                    No display
                                    I have same problem likes yours. Did you solved yours? Please share.
                                    • Boys09
                                      • May 2017
                                      • 12
                                      • Klaten
                                      #38
                                      Originally posted by polytek
                                      try this: bios and ec file and post a feedback:
                                      password winrar please....
                                      • techman1025
                                        • Jun 2014
                                        • 497
                                        Here
                                        Techman1025
                                        • techman1025
                                          • Jun 2014
                                          • 497
                                          Here also with clean me region
                                          Techman1025
                                          The Aspire E5-473 acer
                                          Compal the LA - C341P (A4WAB)
                                          the rev: 1.0
