Hello guys I need your help to find schematic for Asus 1015E, it's because i have problem to find drop on 19v, thanks for your help
Asus 1015E schematic
by ShadowAiHello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,... -
by Fisch46I'm not new to this board but this is my first posting so I hope I'm doing this right. I'm looking for the schematic for a ASUS N550JV motherboard P/N: 60NB0860-MB1B10. I have the board view but need the schematic also. TNX
Channel: Schematic Requests ONLY!
07-31-2025, 07:12 PM -
by mysnoopyHello
I need schematic for this model ASUS FX516PC R6.0
Thanks.-
12-27-2024, 03:41 PM -
by SJones88I am looking for a board view and schematic for my Asus M6500XV R9 7940HS / 16GB DDR5 RTX 4060 Laptop the laptop board markings show M6500XU R2.0 (I am assuming the XU / XV naming here are probably the same board but different GPU/CPU/RAM/SSD/Screen configuration but uses the MX6500 MU board in the range of these laptops)
09-29-2025, 11:27 AM -
Asus P4SD-LE-C Motherboard Schematic
ASUS P4SD-LA (HP OEM) is a motherboard based on the Intel 865G...-
Channel: Schematics and Boardviews
10-21-2024, 05:51 AM -
- Loading...
