hp15 DA0U92MB6D0 schematic needed
  • ranjanlaptop
    • Dec 2013
    • 207
    • india
    DA0U92MB6D0 REV
    MODEL-U92
    737138-001
    help me please
  • khaahk
    • Dec 2013
    • 743
    • Estonia
    Re: hp15 schematic needed
    Quanta U92
    • looofy
      • Jul 2015
      • 34
      • sudan
      thans
      • Nasir Raja
        • Mar 2014
        • 21
        • United Kingdom
        Thanks for sharing blesss
        • talat1
          • Jun 2017
          • 17
          • gaza
          thans
          • menshawy
            • Aug 2013
            • 397
            • egypt
            • whitevolf
              • Feb 2014
              • 122
              • TÜRKİYE
              thanks
              • lolohacko
                • Apr 2018
                • 36
                • Iran
                thanks
                • siroos_tz
                  • Feb 2014
                  • 119
                  • the UK
                  Originally posted by khaahk
                  Quanta U92
                  thanks
                  • bajdik
                    • Aug 2015
                    • 64
                    • Czech Republic
                    Thank you very much!
                    • James Mi
                      • Aug 2020
                      • 30
                      • Ecuador
                      thanks!
                      • I2LIBRE
                        • Sep 2021
                        • México
                        Quanta U92
                        THAKS
                        • jesi
                          • Jul 2013
                          • 61
                          Re: hp15 DA0U92MB6D0 schematic needed
                          nice one brother
                          • chenwei
                            • Feb 2023
                            • 35
                            • china
                            Boardviews
                            • mcthr
                              • Aug 2019
                              • 25
                              • Philippines
                              thank you
                              • Macias
                                • Nov 2019
                                • 83
                                • Ecuador
                                Thaks
                                • NEOCRIVI
                                  • Aug 2010
                                  Boardviews
                                  Thanks friend!
                                  • Ven
                                    Dynabook Satellite Pro L40-G-102 Schematic Needed
                                    by Ven
                                    Dynabook Satellite Pro L40-G-102 Schematic Needed.
                                    02-24-2025, 06:21 AM
                                  • re-atari
                                    Gigabyte GA-H110-D3A schematic/boardview needed
                                    by re-atari
                                    Hello all,
                                    Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
                                    This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
                                    02-24-2025, 06:45 PM
                                  • camisao
                                    MSI GF63 12UDX-234XPT - MS-16R81 VER:2.0 - Schematic needed
                                    by camisao
                                    I need your help finding the MSI GF63 12UDX (Board MS-16R81 VER_2.0) schematic.
                                    I accidently inserted MSI USB a programmer that was connected to a board that has Neutral tied to GND, instead of connecting it to the USB-ISO that was on another port (Friday afternoon mistakes....).
                                    Now it doesn't start. 😏
                                    I've looked for burned parts but found none.
                                    The 20V from the adapter are ok and the battery has 12V if I disconnect the battery plug.
                                    I need the schematic to try to understand where there the problem may be or if it is repairable.
                                    Thanks!...
                                    12-02-2024, 05:30 AM
                                  • Gau_saha
                                    Schematic needed GA-H61M-S REV1.1
                                    by Gau_saha
                                    Sir ,
                                    I need the schematic of h61m-s rev1.1 gigabyte motherboard.
                                    Recently this board came to me for repair but could not find its schematic .
                                    The problem of this board is no display but the board has a power on it .Processor is not heating .
                                    For preliminary investigation i changed vga cable ,ram and processor but the same issue persist.
                                    Whenever i switch on the motherboard monitor says NO SIGNAL .
                                    The board is almost new .No sign of corrosion on the board seen .
                                    10-16-2024, 08:48 AM
                                  • c_vasiloiu
                                    Dell Chromebook 11 CB1C13 (Da0zm7mbac1 Rev C) schematic needed
                                    by c_vasiloiu
                                    It seems that the 16GB eMMC has some problems and I would like to install a bigger hard drive, a regular 2.5" SATA SSD drive. On a similar laptop schematic (Quanta ZM8 r1A) It looks that the CPU Celeron 2955U has some SATA ports available that may have some test points on the motherboard.
                                    Can somebody help with the schematic and to confirm if a SATA SSD drive can work with wires connected on these test points? Also a SATA SSD drive can work with +3.3V taken from the motherboard?
                                    09-07-2024, 04:21 PM
