schematic for 820-2796-a macbook air 11 2010
  • highpulse
    i hate HP
    • May 2013
    • 1489
    • portugal
    well this come from another store , they told us they have replaced the entire top cover with keyboard , since the outher one was with the small board attached near the touchpad full of corrosion due to waterdamage , they order another one , and doest not turn on , we UC the board and seems with a good aspect , but now still not turn on ,
    for what i've measured i only got one coils with 8.35 volts , in this case L7030 , on the Q7030 on the drain got 16 volts , on the source it drop to 8.35v .
    trying to find out also were is the g3hot pin for i can make a direct jumper to see if it start.
    i got the correct board view but the wrong schematic
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    Re: schematic for 820-2796-a macbook air 11 2010
    try this: http://www.informaticanapoli.it/down...B%20K99%29.pdf
    tnx to napoli from italy
    • highpulse
      i hate HP
      • May 2013
      • 1489
      • portugal
      forgot to mention i found it minutes after posting this post .
      im with some doubts , i know you are a pro on maxs , dellxps
      cheked that the big coil near the 3ghot u6990 , have 8.35 volts , is that normal ^? and were is the G3hot pin for i can make contact to see if it work
      • dellxps15
        • Feb 2014
        • 1598
        • italy
        look board view
        press N
        smc_onoff_l
        probe 666 . short with pin 2 of r5014.
        • highpulse
          i hate HP
          • May 2013
          • 1489
          • portugal
          dellxps , ok got 3.,42 on once i shunt between gnd and the 3.42 pin , drop to 0 , but machine does not turn on . wich things you think i should fallow first , on regular laptop i know were to move and what to chek , macs im not expert , its like im newbie in macs , so any help will be welcome
          • dellxps15
            • Feb 2014
            • 1598
            • italy
            very simple : on page 3 of schematic there is the power sequence.
            check for 3.3 volt if present or not.
            edit: macbook air work with 8.5 volt so 8.5 volt are ok.
            • highpulse
              i hate HP
              • May 2013
              • 1489
              • portugal
              ok , i found here that bios as any voltage present , should have at pin 8 of u6100 3 volts but nothing is present.
              btw meanwhile i went to chek the main regulator and found that r7260 one of the sides was green due to the oxidation , trying to clean it well but i think this resistor it broken in one side , finding a matching Resistor will be hard , it have a none regular value
              • dellxps15
                • Feb 2014
                • 1598
                • italy
                the smaller resistor kit i have found are 0402. i think 0201 and 010x are not available right ?
                • highpulse
                  i hate HP
                  • May 2013
                  • 1489
                  • portugal
                  they are way to small , i found another mac board , i found a very near resistor 22k but they are bigger than the one on the macbook air , dont fit .
                  Altough , i got 1.20 on does places were both resistor are , and both are damaged 10k and 23.2k ,
                  and no 3.3 on bios , or on the coil
                  • dellxps15
                    • Feb 2014
                    • 1598
                    • italy
                    u7201 is for 3.3 . 5volt present after power on.
                    no 3.3 on bios is not ok if it's a core duo.
                    new i5 i7 have 0volt on bios . volt comes only afer pressing power botton.
                    • Mogli1476
                      • Feb 2015
                      • 36
                      Hey @all!
                      I have the same liquid problem on my MacBook Air 11inch Mid2011 i7. After liquid spill of milk the bokk won't turn on. cleaning everything with isopropanol but nothing happens. Now i found a missing part on the logic board and need the schematic and board view to identify.
                      Does anybody have both for me? It's a A1370 Model.
                      Thanks a lot and best regards, Mike
                      • dellxps15
                        • Feb 2014
                        • 1598
                        • italy
                        hi post mainboard pictures with good quality and mark where milk or oxidation zone u had.
                        • horiparts
                          • Mar 2017
                          • 5
                          • Brazil
                          Hello
                          I have a macbook A1370 820-2796
                          Keyboard and touchpad do not work
                          I already did all the checking and everything is looking correct according to the schematic.
                          I changed the touchpad, the flat, and the board underneath the touch.
                          all voltages are correct
                          but it still does not work
                          Anyone have any suggestions on what the problem might be?
                          • envym
                            MacBook Pro 2018 with Activation Lock
                            by envym
                            Hi everyone!
                            I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                            I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                            06-27-2025, 08:54 AM
                            Apple MacBook Air 13'' LATE 2010 820-2838 820-2838-A 820-2838-B Boardview
                            Apple MacBook Air 13'' LATE 2010 820-2838 820-2838-A 820-2838-B Boardview...
                            10-22-2024, 02:37 AM
                          • u666sa
                            HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                            by u666sa
                            Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                            Platform: ipa32 la-m024p rev 1b
                            Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                            I found a short on the other side:
                            10-04-2025, 05:03 PM
                          • Flasman90
                            Macbook Pro DFU Restore Issues
                            by Flasman90
                            I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                            - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                            - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                            08-30-2025, 10:27 AM
                          • tobeend
                            Bypass mdm macbook m2 ventura
                            by tobeend
                            1. RESET MACOS WITH IPSW
                            a. Power off MacBook, press and hold the power button to enter Recovery
                            b. Open Disk Utility, remove Macintosh HD
                            c. Reboot, connect to the network to Activate Mac.
                            d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                            d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                            e. Release the other keys, but keep holding the Power key for another 10 seconds
                            f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                            05-26-2023, 07:18 AM
