Hello. need schematic for this one to solve thermo control problem
MESI EX610 MS-163D schematic needed
Tags: None
Re: MESI EX610 MS-163D schematic needed
There are only http://**************/load/noutbuki/platforma_msi/msi_ms_1634_ms_163d_ms_16341_ms_163d1_boardview/319-1-0-28288
MSI MS-1634, MS-163D, MS-16341, MS-163D1 - BOARDVIEW -
thnx, i already found that MS-1634X schematic looks like the one i need, but boardwiev helps too.
now i wait for new AMD TK-55 processor because to bad fun its possible that thetmoprobe in it will be bad because it show me 191c!!!Comment
by ThetechdudeHi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
Thanks.-
Channel: Schematics and Boardviews
Schematic needed (and boardview if available).
Thanks.-
by knk2729dag3bembcd0 rev d Board view and Schematic needed for Non Graphic Conversion (DIS to UMA) as the Graphic chip is bad
by re-atariHello all,
Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...-
- Loading...
