I need SCHEME DELL D630 "PP18L"
    Dell Latitude D630 Laptop Schematic
    LA-3302P LA-3301P...
    10-08-2024, 12:19 PM
  • Akhlz001
    by Akhlz001
    09-20-2025, 07:15 PM
  • master3112
    by master3112
    07-29-2025, 01:55 PM
    Dell Thunderbolt Firmware
    by SMDFlea
    Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
    Some models have a choice of 2 different firmwares, it depends on the dell SKU.
    The SKU is in brackets (****)
    EDIT: NVM65...
    01-26-2025, 06:22 AM
  • F R 2568
    Dell Latitude 5420 does not start (no post) need help to find the reason why
    by F R 2568
    Hello all,
    this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
    I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
    If the laptop is only connected to the AC adapter (battery removed):
    When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
    The power/battery...
    01-08-2025, 05:45 AM
