PT10G a300 schematic
    For a long time im searching this schematic but no luck , anyone to send me this , ??
    got here one not doing anything , since im not receiving ENTRIP1 to activate the bloody 5 volts line ad all schematic i have are different , i think i got all a300 schematic less this one :s
    anyone can send me the pt10G schematic _??? thk in advance
    Re: PT10G a300 schematic
    well fixed that situation about the entrip , fopr what i know there was no EC_PW_ON so replacing KBC solved problem , 5 volts works and turn on , but it turn on 5 second after turn off , then it turn on again and stay on ... i got good voltage on cmos bat , flashed bios allready , this nec was changed some good time ago , meanwhile it came back and notice someone replaced the nec with 6 tantalum caps , but dont look a good job ... would be good havig this schematic to be more sure about certain circuit parts.
    thk in advance
      well . redone (NEC) but this machine really starting to annoying me .
      turn and turn off 6 sec after , turn on again 2 sec after , then stay on , but no image ..
      all voltages on coils are ok .
        try those
        good luck
        Im Back... sort of...
          well tomorrow i will chek but the one i needed was the PT10G and i think you sent me that one . many thank , tomorrow i let you know
            well i guess this pt10g is a bitch all the time with the 5 volts line , its not the first or the last one ,
            that i got with short on 19 volts line , fix the short , then i can get 3,3 with no problem , but altough 5 volts line not working . chekedd all board and no short found on 5 volts line , no green led as well . usually charger does this (not having 5 volts enable) but all is good with charger (acn pin is with 5 volts as it should be . therefore , cheking main regulator 51125 , only entrip 2 have 1.5 volts , entrip 1 is 0 , and this state beein low makes the 5 volts to be not enable ....what a pain in the ass boards
              well found the problem , there is no EC_PWR_ON
              so therefore if no power on the gate on Q34 then q35 will make entrip to 0
                kbc replaced solved the issue
                  wow man, congratz
                  your skill is amazing
                      I would like to use the same schematics for my board, but i realized that it is A03 (PT10g - 6050a2171501 - rev a03).
                      Does anyone have it ?
                      Thank you in advance
