hey guys need l755 toshiba schematic
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    Hey guys , got here a toshiba l755 dam have some components damaged , the board number and rev are the following.
    BS_R/TK_R Main board
    REV : 2.1
    PN 08n1-0na1j00
    need this , i see mosfets blow on the 3.3 and 5 volts line but also the main regulator .. for what i know is a richtek since its name is JD=GD
    cheking the richtek list thata th3_uniqu3 shared on the forum . is a bit confused , since they are several possibilities for the richtek controler .. so if anyone can help in advance wit the schematic would be nice.
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    Re: hey guys need l755 toshiba schematic
    no one O.o ?
    • p1muserfan
      • Apr 2014
      • 184
      Welcome to my hell, have a similar board BS AS Rev 2.1 p/n 08n1-0n93j00. Mine is also marked as a Hannstar MV-4 94V-O. Can't even come close to finding a print. Very few markings on the board too
      • hansie55
        • Dec 2013
        • 254
        • Netherlands
        Maybe this one is of use?
        • highpulse
          i hate HP
          • May 2013
          • 1488
          • portugal
          not even close , and its a intel board with discrete gpu .
          but thk anyway mate
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            try this one, its UMA but closer than other
            i keep digging for other
            Im Back... sort of...
            • ala_borbe
              aka Donald
              • 1625
              • Malta
              end more, maybe they help
              • highpulse
                i hate HP
                • May 2013
                • 1488
                • portugal
                nop none of does works , mine have a main regulator of 20 pins
                JD=DG (thats mi still trying to understand wich richtek is it on the richtek list
                • highpulse
                  i hate HP
                  • May 2013
                  • 1488
                  • portugal
                  but thk for the schematics
                  btw the regulator is a RT8239C must get one or a similar
                  • ala_borbe
                    aka Donald
                    • 1625
                    • Malta
                    from all i see, this should be BLBD mother board
                    can you see for any other markings, and maybe you could post bios dump, may be useful in identifying motherboard
                    gl
                    maybe this could be it?
                    http://www.yifix.com/thread-3275-1-1.html
                    • highpulse
                      i hate HP
                      • May 2013
                      • 1488
                      • portugal
                      monday , once i arrive to the lab i will give more info about this motherboard , and main principal components.
                      • atsio
                        • Oct 2013
                        • 819
                        • Greece
                        That's a Pegatron BS_R/TK_R. There is not a schematic available yet.
                        • highpulse
                          i hate HP
                          • May 2013
                          • 1488
                          • portugal
                          shitttt :S well at least if someone help me out , figuring wich richtek is the main regulator is all what i need for i can start the fix , since after lifting the mosfets , i notice no shsort on coils ,. and only the 2 mosfets are burned and the main regulator, the richtek is a JD=DG
                          • Ramee
                            • Jul 2014
                            • 218
                            • Israel
                            JD=DG=RT8239 is the Main Power Supply Controller that gives 2v to 5.5v output voltage.
                            Like LDO3 and LDO5.
                            • highpulse
                              i hate HP
                              • May 2013
                              • 1488
                              • portugal
                              ramee that i know is the main reg ehehh i just wanted to know wich is the exact richtek since on the richtek list it gives me a few options .. and like this it becomes fucked up to know wich one to use. thk for the tip mate , btw wich code you use from the full code on the chip to know wich richtek is the right one ?
                              • highpulse
                                i hate HP
                                • May 2013
                                • 1488
                                • portugal
                                not even showing up on the richtek list this RT8239
                                • highpulse
                                  i hate HP
                                  • May 2013
                                  • 1488
                                  • portugal
                                  RT8239 is usualy for JC not JD .
                                  but google is saying the same . well will try orderig or find out a compatible
                                  btw it must be RT8239C for the JD code
                                  • Ramee
                                    • Jul 2014
                                    • 218
                                    • Israel
                                    RT8239A, B or C has the same function.
                                    I could not find the site where i found it;(
                                    • highpulse
                                      i hate HP
                                      • May 2013
                                      • 1488
                                      • portugal
                                      well its bit different on the pin 13 , meanwhile al the outher function , EN and ldos and Pgood are in same position
                                      • spidey
                                        climbs
                                        • Dec 2012
                                        • 644
                                        • Cyprus
                                        richtek marking codes :
