Hp 640 g8 ProBook schematic
This topic has been answered.
  • dandymon
    • Apr 2025
    • 10
    Hi folks.
    I have a 640 which doesn’t charge using the barrel connector, only via USB. Internal voltage rails only go up to 12V, they rise to 19.5 with the USB C.
    Can Anyone who has the schematic lend a hand? I can read them fine so just a link would be great, but also any insight if you’ve seen this before.
    Also, is there a list connecting the HP series model
    numbers to the COMPAL model numbers?
    thanks
    dan
  • Answer selected by dandymon at 07-24-2025, 12:48 AM.
    SMDFlea
    • 21869
    Originally posted by dandymon
    Anything sitting on your hard drive SMDFlea?
    I don`t have it, its not available yet as far as i know, but the DAX8QAMB8D0 is similar https://www.badcaps.net/forum/troubl...37#post3684937
      • 21869
      thanks
      dan
      Post the motherboard model number.
      Beginner's guidelines
      https://www.badcaps.net/forum/troubl...r-s-guidelines
      1.1.3 Motherboard model number
      • dandymon
        • Apr 2025
        • 10
        Before now, Never did I ever know there was a model number that wasn’t 640 G8!
        I think 43A58EA#ABU looks like the number?
        thanks SMDFlea
          • 21869
          thanks SMDFlea
          Not the laptop model number, the motherboard model number. Should be DA0X8QMB8E0 or something similar
          • dandymon
            • Apr 2025
            • 10
            #embarrassing
            DAX8QMB38A0 RevA
            (photo attached for other noobs who find this thread.)
            thank you
            • dandymon
              • Apr 2025
              • 10
                • 21869
                • dandymon
                  • Apr 2025
                  • 10
                  Thank you very much. Sorry about the delayed response in doing so. Seeing as it’s a power supply issue, I’m pretty convinced that the schematics will be pretty identical at that stage in the circuit. I’ve had a little read through and it seems that my problem with the barrel connector only spitting out 12 V could be well down to some of the P type fets or a zener gone wrong. Either way, the circuit gives me a great hint as to how the USB and barrel connectors work together.
                  Really appreciate it, thanks mate
