Need schematic and board file ROG G513Q, G533-6050A3249001-NFC-A01(A1)
  • SmallfishDIY
    • Apr 2025
    • 4
    Guys,
    i’m tryna fix the motherboard, boots up and works fine until it does not want to boot. I quit using it for few days and works fine for a day and does the same thing again and lingers at the boot screen. Any ideas what could be wrong?
    schematic please! ROG g513q
    g533-6050a3249001-nfc-a01(a1)
    thanks in advance!
  • SmallfishDIY
    • Apr 2025
    • 4
    Motherboard
    • Lisa Su
      Badcaps
      • Apr 2021
      • 216
      • Taiwan
      Originally posted by SmallfishDIY
      Motherboard
      I think that's just the part number for the NFC module, not the actual motherboard ID/part number.
      Check the area just above the RAM slots. It should look something like G513-6050A3249301-MB-A03.
      • SmallfishDIY
        • Apr 2025
        • 4
        You're right! Thanks! I think this is the right one now. Lmk! Click image for larger version
        • SmallfishDIY
          • Apr 2025
          • 4
          I'm posting the correct MB number G533-6050A3250203-MB-A01 (A1)
          Any luck with the schematics guys?
          Thanks a lot!
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • m1ch43lzm
            Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
            by m1ch43lzm
            Hi everyone
            I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
            Programmer models: XGecu TL866II Plus / T48 / T56 / T76
            Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
            There's also an extra OTP Secu.R...
            09-06-2025, 05:47 PM
          • alegatorul
            Cello Tv . wifi 40" board HK.T.RT2841P638 wrong file update
            by alegatorul
            hi,
            i've being using this Cello tv, uk brand, C40rts, HK.T.RT2841P638 main board, for a year or more.
            Last week i've found an update, 3rd party, that i though it was close to my board. Inserted on a usb stick the install.img, started the Firmware update, ended, rebooted and nothing. The led (red-green) keeps flashing, backlight is on but to response on remote.
            I've retried with original fw, no success. Hooked the uart Cp2102, putty, tried to swuu command (to update from usb), it goes for a while the get "cpu reset" on laptop screen that brakes the process and halt....
            11-03-2024, 02:28 AM
