ACER A515-48m DA0ZA2MBAD0 request boardview or schematic
  • xomjak
    • May 2022
    • Ukraine
    I am looking for a board view and schematic for the Acer A515-48M laptop. The motherboard is DA0ZA2MBAD0 Rev: D.
    The motherboard was damaged by liquid spill, specifically in the area of the 3V power management IC. After cleaning all traces of liquid, I found a low resistance of 8 ohms on the 3V rail.
    I removed the Type-C charging controller due to overheating, and the resistance on the 3V rail increased to 430 ohms. However, this still seems too low.
  • kachergames
    • Jul 2014
    • 12
    • mexico
    Anyone else! With this schematic
    • mkdj
      Acer TravelMate P214 - N19Q7 main power rail shorted to ground
      by mkdj
      Dear all,
      I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
      I have checked resistance across each of the 4 MOSFETS. I have the following readings:
      Both N-Channel Mosfets: nothing odd
      P-Channel MOSFET number 1:
      source - drain : 117 kOhm
      source - gate: 96 Ohm
      gate - drain: 117 kOhm
      P-Channel MOSFET...
      08-20-2025, 06:08 AM
    • atunguyd
      Acer x163w Monitor PSU schematic
      by atunguyd
      Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
      The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
      03-05-2025, 02:08 PM
    • reformatt
      LA-N631P schematic and boardview request
      by reformatt
      This is from a 2024 Acer Aspire 15 N23C3. Unit has liquid damage but CPU seems to have survived. Can't find anything on this board, but have noted the following until a schematic becomes available.
      PUA01 RT6543AGQW (ML=) PCH +1V
      PUZ101 RT3624BE CPU Vcore
      PU301 RT6338BGQUF (RW=) +3.3V
      PU501 RT6310CGQUF (S2=) +5.1V
      PUM1 TPS51488 RAM +1.2V
      PUB1 Intersil 9238 B+
      UVH2 EM5109-A +3V LDO
      UK1 KB9542QG EC
      Main issues for this board are a hole in the PCH power IC PUA01. The hole is right on the L part...
      04-03-2025, 01:33 AM
    • Nagy Daniel
      Lowest possible resistance on laptop motherboard rail - Guide Table request
      by Nagy Daniel
      Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
      I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
      I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
      So, I generated a table with AI so I can...
      03-04-2025, 08:24 AM
    • Kalman27
      Acer A514-55-511P liquid damage
      by Kalman27
      Hello guys,
      I have an Acer A514-55-511P liquid damaged, and one component seems to have failed, but I can't figure out what this is.
      Thank you. ...
      09-12-2024, 07:14 AM
