15u530 main board mp rev 1.5 schematic
  • Prabuth
    Technician
    • Sep 2018
    • 77
    • Sri Lanka
    15u530 main board mp rev 1.5 Schematic Need pleace..
    LG Laptop..
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
  • ygorsan
    by ygorsan
    🧩 Problem Summary:
    • I
    07-28-2025, 08:34 AM
  • jb_Bak
    by jb_Bak
    CN6401
    Pin 01 NC
    Pin 02 NC
    Pin 03 "BL_ON": 0V
    Pin 04 "N/C"
    Pin 05 "STBY 3.3V": 3.5V
    Pin 06 "GND": N/C
    Pin 07 "AC_OFF"...
    09-27-2021, 04:52 PM
  • JDC
    by JDC
    ONN 100012588
    Long answer:
    07-15-2022, 07:39 AM
  • cheeky2
    by cheeky2
    05-25-2024, 03:27 AM
