Sony PCG-6L1N Schematics
  • dspok
    • Jan 2014
    • 553
    • Nepal
    Schematic required for said model. Anybody having this schematic please help.
    It has problem with LCD backlight. I checked TCON board fuse which not getting full voltage & I cannot find fuse on the board.
    I suppose that nVidia chip has problem but I want to be sure before reflowing/reballing it.
  • taufeeque ahmed
    • Sep 2011
    • 6
    Re: Sony PCG-6L1N Schematics
    send the correct model number you will find on front panel back panel
    and if you open laptop give the board number and ver of board if possible send image of motherboard
    • taufeeque ahmed
      • Sep 2011
      • 6
      your lcd backlight is not working give details of voltage reading of inverter board
      • dspok
        • Jan 2014
        • 553
        • Nepal
        @taufeeque ahmed
        its alright, i managed to fix it.
        • mrautom8
          Samsung TV UN75H6350AFXZC main board schematics?
          by mrautom8
          Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
          Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
          While relay is on, all voltage rails are present and steady (scoped) on main board.
          I love a good logic puzzle but getting lost without any schematics.
          No shorts on ANY capacitor main board.
          Thermal camera shows 3.3V inductor getting warm instantly but...
          10-19-2025, 06:32 PM
        • Rezendes
          Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
          by Rezendes
          Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
          I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
          The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
          05-10-2024, 02:18 PM
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • delpiero3
          Sony Vaio SVS MBX-261 board failure
          by delpiero3
          Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
          Nevertheless, let's say, i don't come as a total beginner.
          I have this old laptop, which suit perfectly my needs, with the...
          10-29-2024, 06:16 AM
