IBM R50e schematics
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Re: IBM R50e schematics
    i replace again U42 but still nothing, no sign of life. Please what to check next, this is older laptop maybe mains doesnt go over this IC?
    On U41 i have only 16V on pin 22 (V+), all other pin is 0V.
    ...the quieter you become the more you are able to hear...
    • rtstorm
      • Feb 2012
      • 971
      • Croatia
      please take a look at page 69. I have 16V on Q2 and Q6 pins 7 and 8. All other pin is 0V. How is this controlled?
      • rtstorm
        • Feb 2012
        • 971
        • Croatia
        i suspect at U41 (MAX 1631AEAI). It has only 16V on pin 22 (V+) and nothing else. As i figured this U41 need to send VCC3M and VCC5M to H8S (U23) and TSURUMAI (U61) but it doesn't.
        Am i thinking in the right way?
        • rtstorm
          • Feb 2012
          • 971
          • Croatia
          hi, i replace U41 but still no power. I am going crazy, is this TSURUMAI (U61) fail? I do not understand this king of fail.
          Please help
          • rtstorm
            • Feb 2012
            • 971
            • Croatia
            hi, i replace U61 (TSURUMAI) no help please any idea?
            • atsio
              • Oct 2013
              • 819
              • Greece
              #26
              What is the voltage on pin 4 of Q34 and Q36? Give also resistance to ground without power supply connected on pins 1,4,8 of Q34 and Q36.
              • rtstorm
                • Feb 2012
                • 971
                • Croatia
                #27
                Q34 pin 4 - 2.85V
                Q36 pin 4 - 10.40V
                Q34 pin 1 - GND = 0.6Mohm
                Q34 pin 4 - GND = 1.1Mohm
                Q34 pin 8 - GND = 201kOhm
                Q36 pin 1 - GND = 201kOhm
                Q36 pin 4 - GND = 1.2Mohm
                Q36 pin 8 - GND = 24MOhm
                • atsio
                  • Oct 2013
                  • 819
                  • Greece
                  #28
                  What is the voltage on pins 1 and 3 of Q32 and resistance to ground without power supply on those pins and all the pins of U42?
                  • rtstorm
                    • Feb 2012
                    • 971
                    • Croatia
                    #29
                    Q32 pin1 - 0.19V
                    Q32 pin 3 - 0V
                    Q32 pin 1 - GND = 39kOhm
                    Q32 pin 3 - GND = 39kOhm
                    U42:
                    pin1 - 24Mohm
                    pin2 - 116kOhm
                    pin3 - 201kOhm
                    pin4 - 38.7kOhm
                    pin5 - 10.8kOhm
                    pin6 - 22MOhm
                    pin7 - 2.2Ohm
                    pin8 - 16.7kOhm
                    pin9 - 33kOhm
                    pin10 - 9.7kOhm
                    pin11 - 35Mohm
                    pin12 - no connection to GND (0)
                    pin13 - 2.4Ohm
                    pin14 - 11.3Mohm
                    pin15 - 16.7kOhm
                    pin16 - 10.8kOhm
                    pin17 - 10.5MOhm
                    pin18 - 11.5MOhm
                    pin19 - 2.2ohm
                    pin20 - 7.8MOhm
                    pin21 - 30kOhm
                    pin22 - no connection to GND (0)
                    pin23 - no connection to GND (0)
                    pin24 - 10.8MOhm
                    • atsio
                      • Oct 2013
                      • 819
                      • Greece
                      #30
                      Check voltages on pins 57,34, 55, 52, 54, 10, 11, 44, 58, 59 of U61
                      • rtstorm
                        • Feb 2012
                        • 971
                        • Croatia
                        #31
                        U61:
                        pin57 - when measuring voltage grow from 0V to 3.19V stable at 3.19V
                        pin34 - 3.21V
                        pin55 - 0V
                        pin52 - 4.2V
                        pin54 - 1V
                        pin10 - 0.2V
                        pin11 - 0.24V
                        pin44 - 0V
                        pin58 - 0V
                        pin59 - 0V
                        • atsio
                          • Oct 2013
                          • 819
                          • Greece
                          #32
                          Check voltage and resistance to ground (with out power supply) on all three pins of D10, D19, D23. Check if diodes are ok.
                          • rtstorm
                            • Feb 2012
                            • 971
                            • Croatia
                            #33
                            D10
                            pin1 - -4.4V
                            pin2 - -4.4V
                            pin4 - 3V
                            pin1 - 280kOhm
                            pin2 - 277kOhm
                            pin3 - 176kOhm
                            diode test OK
                            D19
                            pin1 - 2.5V
                            pin2 - 2.5V
                            pin4 - 2V
                            pin1 - 270kOhm
                            pin2 - 270kOhm
                            pin3 - 170kOhm
                            diode test OK
                            D23 - i do not have it on my board, that spot is empty.
                            • atsio
                              • Oct 2013
                              • 819
                              • Greece
                              #34
                              Did you had the battery connected while you were taking measurements of voltages?
                              • atsio
                                • Oct 2013
                                • 819
                                • Greece
                                #35
                                Check voltages on all pins of Q13 and on both sides of R422 and R453.
                                • dj_ricoh
                                  • 2073
                                  #36
                                  i think there is something shorted to ground !
                                  like a cap!
                                  and lift the L5 coil
                                  • dj_ricoh
                                    • 2073
                                    #37
                                    see pin 24 on U42 10Mohms. pff
                                    go to q4 and that coil
                                    • atsio
                                      • Oct 2013
                                      • 819
                                      • Greece
                                      #38
                                      like a cap!
                                      What? When all resistances measure allright.
                                      • rtstorm
                                        • Feb 2012
                                        • 971
                                        • Croatia
                                        #39
                                        @ atsio
                                        Q13
                                        pin1 - 2.99V
                                        pin2 - 2.89V
                                        pin3 - 2.89V
                                        pin4 - 1.2V
                                        pin5 - 15.96V
                                        pin6 - 15.96V
                                        pin7 - 15.96V
                                        pin8 - 15.96V
                                        R422 i cannot find (KODIAK program wont display it)
                                        R453 one side is 16.3V and other side is -7.8V
                                        I did not use the battery while i was testing.
                                        • rtstorm
                                          • Feb 2012
                                          • 971
                                          • Croatia
                                          #40
                                          Q4
                                          pin1 - 0.3V
                                          pin2 - 0.56V
                                          pin3 - 0V
                                          pin4 - 0V
                                          pin5 - 0.3V
                                          pin6 - 0.3V
                                          pin7 - 16V
                                          pin8 - 16V
                                          L5 coil have 0.3V on both side
                                            Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                            09-06-2024, 09:30 PM
                                            Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 08:47 AM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
                                            Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 06:11 AM
