IBM R50e schematics
    IBM R50e schematics
    Hello, please i need schematics for this laptop it wont start.
    Thank you
    ...the quieter you become the more you are able to hear...
    Re: IBM R50e schematics
    https://www.youtube.com/watch?v=NRmkjYiYGhE
      thanks, i found that on page 67 i have only input V+ 16V (this laptop has 16V adapter) but no output on that MAX1631 IC. I have some small voltages coming of but nothing above 1V
        What are the voltages on pins 9,21,23 of U41?
        What are the voltages on pins 52, 57, 59 of U61?
          On U41 pin 9 is 0V, pin 21 and 23 are oscilating from 0V to 0.2V
          On U61 pin 52 is 0V, pin 57 is 15,9V and pin59 is 0V
            Which IC is U61?
              it is toshiba tb62501f
                I think your problem is the Toshiba but better check it first.
                Check on U61 voltages on pins 1, 2, 55, 52, 54, 44, 58.
                  pin 1 - 0V
                  pin 2 - 0.3V
                  pin 55 - 0V
                  pin 52 - 0V
                  pin 54 - 5.6V
                  pin 44 - 0V
                  pin 58 - 0V
                    Give voltages on all pins of U42.
                      U42:
                      pin 1 - 15.93V
                      pin 2 - 16.38V
                      pin 3 - 16.38V
                      pin 4 - 0V
                      pin 5 - 0V
                      pin 6 - 0V
                      pin 7 - 0V
                      pin 8 - 0V
                      pin 9 - 0V
                      pin10 - 0V
                      pin11 - 0V
                      pin12 - 3V
                      pin13 - 0V
                      pin14 - 0.2V
                      pin15 - 0V
                      pin16 - 0V
                      pin17 - 0.2V
                      pin18 - 0.2V
                      pin19 - 0V
                      pin20 - 0V
                      pin21 - 0V
                      pin22 - 0.3V
                      pin23 - 0.2V
                      pin24 - 0.2V
                        I think your charger is dead and you must change it.
                          you mean this U42 (High Frequency Switch Mode Li-Ion Battery Charger)
                            Yes. It sends signal to enable U61 which sends signal to enable MAX.
                              hi, i replaced the U42 but laptop still wont start
                              i check U41 and U61 all voltages are still the same. I test this widouth pushing start button is this ok?
                                What are the voltages on U42?
                                  U42:
                                  pin 1 - 16V
                                  pin 2 - 16V
                                  pin 3 - 16V
                                  pin 4 - 0V
                                  pin 5 - 0V
                                  pin 6 - 0V
                                  pin 7 - 0V
                                  pin 8 - 0V
                                  pin 9 - 0V
                                  pin10 - 0V
                                  pin11 - 0V
                                  pin12 - 0V
                                  pin13 - 0V
                                  pin14 - 0V
                                  pin15 - 0V
                                  pin16 - 0V
                                  pin17 - 0V
                                  pin18 - 0V
                                  pin19 - 0V
                                  pin20 - 0V
                                  pin21 - 0V
                                  pin22 - 0V
                                  pin23 - 0V
                                  pin24 - 0V
                                  i this this is bad IC too, whyt did you think i have input (VCC, SYS+ and SYS-)
                                  Maybe i have some solder bridge between pins, i this i should have some output from IC
                                    Which ADP charger IC are you using as replacement?
                                      From the charger datasheet:
                                      "System Current Sense
                                      An uncommitted differential amplifier is provided for additional
                                      high side current sensing. This amplifier, AMP2, has a fixed gain
                                      of 50 V/V from the SYS+ and SYS– pins to the analog output at
                                      ISYS. ISYS has a 1 mA source capability to drive an external
                                      load. The common-mode range of the input pins is from 4 V to
                                      VCC. This amplifier is the only part of the ADP3806 that
                                      remains active during shutdown. The power to this block is
                                      derived from the bias current on the SYS+ and SYS– pins."
                                        I use the same ADP3806 charger.
                                        So it must have some output when laptop in stand by?
