HP DA0G7GMB8F0 REV:F Boardview and schematic
  • Darren Hibbert
    • 116
    Hi guys.
    Does anyone have the boardview and schematic of this board please?
    Many many thanks.
    Darren.
  • bhachi
    Jkhatri
    • Jul 2021
    • 20
    • india
    here you go ... the schematic ( near about not the same but works for reference ) and Boardview
    °v°
    /(_)\
    ^ ^ JKhatri​
    • ender_33
      • Oct 2016
      • 7
      • venezuela
      • hendrik bayu saputro
        • Nov 2024
        • 6
        • indonesia
        Thank you master, may God bless you
        • SRJoint
          • Feb 2022
          • 11
          THANKS BRO
          • ravi_1617
            YY Solutions
            • Jan 2012
            • 348
            • India
            • ravi_1617
              YY Solutions
              • Jan 2012
              • 348
              • India
              Thanks for both
              • AustinCER
                In Search of Schematic/Boardview for Lenovo Ideapad Flex 5 14ALC7
                by AustinCER
                I am in search of a schematic or boardview for Lenovo Ideapad Flex 5 14ALC7.
                No power and no charging LED with AC Adapter connected. AC Adapter is functioning at 19V, and also tried another Lenovo AC Adapter -- no charging LED still.
                There is an active 19V from the USB-C port to the motherboard with AC Adapter connected, so the port is also fine. I am assuming there is a short on one of the power rails, but don't know where to start looking.
                Any insight, schematic or boardview would be greatly appreciated.
                Model: Lenovo Ideapad Flex 5 14ALC7...
                11-04-2025, 03:49 PM
              • PacoGT
                HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
                by PacoGT
                hello firends
                i search the schematic or boardview
                I have this motherboard, but I can't find the schematic or the boardview.
                The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
                So the computer doesn't turn on, and the 3V disappears after a few seconds.
                The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
                The new problem arose after removing the bad chip.
                3V and 5V remained together,...
                08-19-2025, 08:25 PM
              • hosain0489
                Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
                by hosain0489
                I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
                Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
                If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
                Thank you very much in advance!
                07-15-2025, 11:20 AM
              • re-atari
                Gigabyte GA-H110-D3A schematic/boardview needed
                by re-atari
                Hello all,
                Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
                This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
                02-24-2025, 06:45 PM
              • jonyhdtv
                HP ProBook X360 11 G3 ee (winbook) schematic and boardview thanks
                by jonyhdtv
                Looking for schematic and boardview
                Model: HP ProBook X360 11 G3 EE
                Serial: SCG9114JG7
                Motherboard: L43774-601
                defect: touchscreen doesn't work (touch works on another computer)
                thanks to all​
                01-29-2025, 08:16 AM
