(Request) PowerBook G3 PDQ/Wallstreet II 820-1014-A main board schematic
  • k24a1
    Computer Witch
    • May 2023
    • 9
    Modifying a spare board to populate the unused VRAM slot and I'd like the schematic so I can see if there's anything else I need to do, or if there's a way I can activate it if it's not enabled by default. P/N is 820-1014-A... yes, it's 26 years old I know!
    Non-binary, she/they. :^))
    Technology enthusiast who likes working on computers, video game systems, and other electronics.
  • piernov
    • Jan 2016
    • 4435
    • France
    Unfortunately it seems like none of the G3 schematics ever leaked, earliest stuff I've seen is from the late G4 era. (or early 68k desktop Macintosh)
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • ygorsan
      by ygorsan
      🧩 Problem Summary:
      • I
      07-28-2025, 08:34 AM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • JDC
      by JDC
      ONN 100012588
      Long answer:
      07-15-2022, 07:39 AM
    • cheeky2
      by cheeky2
      05-25-2024, 03:27 AM
