XPS 9530 LA-L663P schematic
  • trunguntilyou
    • Aug 2022
    • 314
    • Vietnam
    please help me ! i need ic name and datasheet,, image below
  • Bonzas
    • 468
    • Indonesia
    It's richtek RT8843AGQW, but on richtek site datasheet only RT8843C
    • trunguntilyou
      • Aug 2022
      • 314
      • Vietnam
      oh so lucky! ,, with your help I solved my problem,, and this ic is in the diagram attached below,,, thank you very much!
      https://www.badcaps.net/forum/troubl...-huaqin-nb6200
      • _adr
        • Jul 2023
        • 5
        • Buenos Aires
        Hi, can i know what problem did you have? I have the same model and its not detecting the nvidia card
        • trunguntilyou
          • Aug 2022
          • 314
          • Vietnam
          If you lose the Nivia power source, check the TON pin resistance of that ic, it's about 200k (can't know exactly because there's no diagram).
          • _adr
            • Jul 2023
            • 5
            • Buenos Aires
            Hi the resistance to ground? Do you happen to remember which one in your picture was it? i cant find it
            • trunguntilyou
              • Aug 2022
              • 314
              • Vietnam
              I don't have a picture, you can check there are 2 resistors on the back, 1 is 0 ohm, 2 is about 200k to replace, the 200k resistor one end is 19v and the other end goes into that ic
              • trunguntilyou
                • Aug 2022
                • 314
                • Vietnam
                On the diagram I sent you, look for PU2001 and you will see that ic and you can check pin 8 of the ic
                • _adr
                  • Jul 2023
                  • 5
                  • Buenos Aires
                  Hi, i think i found the 8 VIN RTON pin, i think that is the one i marked with green, i cant seem to find the two resistors you're refering to, i did take a photo of the back can you help me to identify which are? tysm
                  • trunguntilyou
                    • Aug 2022
                    • 314
                    • Vietnam
                    try
                    • trunguntilyou
                      • Aug 2022
                      • 314
                      • Vietnam
                      Coincidentally, I just encountered it again and I just needed to replace the 2nd resistor = 200k and it was successful
                      • _adr
                        • Jul 2023
                        • 5
                        • Buenos Aires
                        Yess, it was open or very high when i was able to read it was 6.7MOhms, then it vanished itself as was like burned gonna change it tomorrow, and it that was the fault ill give you some reward, tysm
                        • trunguntilyou
                          • Aug 2022
                          • 314
                          • Vietnam
                          good luck ,, please donate to this forum not me
                          • tiofilo
                            • Feb 2020
                            • 18
                            • Mexico
                            I confirm, same issue, that resistor is damaged maybe broken or burned, replaced it and all is good now, thanks.
                            • eastcoastcomputing
                              • Feb 2023
                              • 58
                              Hi there,
                              I'm trying to get the schematics and BV for a Dell XPS 15 9530 (motherboard: LA-L663P)... Can anyone help?
                              The board powers up for a couple of seconds then shuts down, no obvious shorts...
                              ​Any suggestions or advice welcome.
                              Thank you
                                SMDFlea commented
                                Editing a comment
                                Thread merged with existing topic.
                            • noipi
                              • Aug 2017
                              • 69
                              • Singapore
                              HELLO, any one have boardview or schematic for this LA-L663P??
                              • d00m178
                                • Jul 2025
                                • Portugal
                                try
                                Hello! would you please re-send your pictures of MB where this resistor located?
                                Im also planning to replace this resistor on my Dell XPS 15 9530 because of NVidia videocard keeps disconnecting after some time.
                                Also - any other confirmation that after replacing this resistor everything goes ok with Nvidia videocard?
                                • trunguntilyou
                                  • Aug 2022
                                  • 314
                                  • Vietnam
                                  i dont have picture ,, Read carefully what i wrote above ,, resistor is 330k can be replaced by 200k ,, it is on the back of PUV1 ,, find by measuring continuity and by impedance ,, definitely resistor is broken and replace it
                                  • d00m178
                                    • Jul 2025
                                    • Portugal
                                    sorru I thought that it was your pictures)
                                    ​seems it your photos of PCB with replaced resistors? would you please share them again?
                                    • TinkerTron
                                      Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                      by TinkerTron
                                      Hey everyone,
                                      I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                      Instead, here's what's been bugging me so far:
                                      The schematic...
                                      03-06-2025, 02:03 PM
                                    • atunguyd
                                      Acer x163w Monitor PSU schematic
                                      by atunguyd
                                      Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                                      The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                                      03-05-2025, 02:08 PM
                                    • ianpoultonknights
                                      Zenbook Flip 15 UX562AI schematic
                                      by ianpoultonknights
                                      Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
                                      06-26-2025, 02:41 PM
                                    • Much Bugs
                                      MSI Z390 A-PRO Schematic and BoardView
                                      by Much Bugs
                                      The Schematic and BoardView( *.cad ) of MSI Z390 A-PRO , the board model no is MS-7B98 Rev1.0-1.1 ....
                                      06-24-2025, 10:13 AM
                                      DELL XPS 9530-6107 Notebook 15 Specification for Upgrade or Repair
                                      This specification for the DELL XPS 9530-6107 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9530-6107 boardview and 9530-6107 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS...
                                      09-07-2024, 07:12 AM
