ASUS ZenBook UX3404 Water Damage - Schematic / Boardview / Component detail Needed
  • EffiSon
    • May 2020
    • 38
    • Sweden
    I have got a water damage Asus Zenbook UX3404 (exact model no. UX3404VC-PURE5) where one of its component got burned, picture attached. MARKING ON COMPONENT is ONLY 5k6 !!
    Wondering does anyone know what is that component, it is located near the GPU. I have found out the same component near the LVDS cable on and that is how conclude that the suspected burned component
    Thank
  • Gcs_rma
    Banned
    • Dec 2023
    • 108
    • N/A
    try Click image for larger version
    • EffiSon
      • May 2020
      • 38
      • Sweden
      Thanks for the quick response. But it does not seems to be the right component since the burned component has only 8 pins.
      I compared again the layout with PCB and found that it is PU2505, can you please share the part no. of it ? and the capacitor below it
      • Gcs_rma
        Banned
        • Dec 2023
        • 108
        • N/A
        ... Click image for larger version
        • EffiSon
          • May 2020
          • 38
          • Sweden
          Thanks again but that is not assembled in your board layout, can you please check the other similar component marked in PURPLE in the new picture attached
          • Gcs_rma
            Banned
            • Dec 2023
            • 108
            • N/A
            23 Click image for larger version
ID:	3257047 Click image for larger version
            • EffiSon
              • May 2020
              • 38
              • Sweden
              Thank you very much.
              I can't find that component available nearby, does anyone have any alternative part number for the given component SY8883
              • EffiSon
                • May 2020
                • 38
                • Sweden
                Hi again,
                Is it possible to share the power cycle of the schematic ? sinice i did not find out the component now i wanted to go and check its power blocks
                or if someone else has any other suggestion ?
                • strongaaa
                  • 4
                  • Istanbul
                  dear friends I need a r Boardview for ASUS ZenBook UX3404
                  ​ Thanks a lot.
                  • Ugur87
                    MacBook Air M4 A3240 Brand New Water Damage no Image
                    by Ugur87
                    I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
                    08-28-2025, 01:09 PM
                  • edugimeno
                    Stagg sms12p audio amp has water damage
                    by edugimeno
                    Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
                    I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
                    There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
                    There is only one signal wire connecting the first boards...
                    05-24-2025, 06:00 AM
                    ASUS ZenBook Zenbook 14 Flip OLED UN5401QA-KN144W Notebook Specification for Upgrade or Repair
                    This specification for the ASUS ZenBook Zenbook 14 Flip OLED UN5401QA-KN144W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Zenbook 14 Flip OLED UN5401QA-KN144W boardview and Zenbook 14 Flip OLED UN5401QA-KN144W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                    09-07-2024, 06:31 AM
                  • Joel Ohana
                    Lenovo IdeaPad 3 15IAU7 that suffered water damage
                    by Joel Ohana
                    I have a Lenovo IdeaPad 3 15IAU7 that suffered water damage. It doesn't turn on (white power light flashes when on button pressed), and the amber light flashes when plugged in.
                    Symptoms:
                    • Short detected – sparks appear when touching the charging port connection with board with a metal (even a multimeter probe).
                    • Visible damage – after cleaning corrosion, I found 4 possibly burnt memory chips near PC3165, labeled UD5, UD6, UD7, and UD8.
                    What are my next steps to diagnose and possibly repair it without replacing the entire board? Any guidance would be greatly...
                    03-06-2025, 11:25 AM
                  • abajor
                    A2141 820-01700 Water Damage L8504 Damaged, U3100/U3200 power cycles UB300/UB400 5V .25A
                    by abajor
                    Like title says A2141 came in with Water Damage, customer desperately wants the data.
                    The actual water ingress doesn't appear too bad it sat for a day but was very dusty internally. I have no idea why L8504 was arced there is no apparent moisture there or around the LVDS cable; however, the LVDS to screen screw studs had popped off at some point and somebody tried securing it with kapton tape.
                    I had to create a micron wire pad jumper to reconnect the south side of the L8504 since the primary pad was blasted down to the vias.
                    That said after cleaning up the...
                    12-21-2024, 07:16 PM
