ASUS ZenBook UX3404 Water Damage - Schematic / Boardview / Component detail Needed
    I have got a water damage Asus Zenbook UX3404 (exact model no. UX3404VC-PURE5) where one of its component got burned, picture attached. MARKING ON COMPONENT is ONLY 5k6 !!
    Wondering does anyone know what is that component, it is located near the GPU. I have found out the same component near the LVDS cable on and that is how conclude that the suspected burned component
    Thank
    try Click image for larger version
      Thanks for the quick response. But it does not seems to be the right component since the burned component has only 8 pins.
      I compared again the layout with PCB and found that it is PU2505, can you please share the part no. of it ? and the capacitor below it
        ... Click image for larger version
          Thanks again but that is not assembled in your board layout, can you please check the other similar component marked in PURPLE in the new picture attached
            23 Click image for larger version
ID:	3257047 Click image for larger version
              Thank you very much.
              I can't find that component available nearby, does anyone have any alternative part number for the given component SY8883
                Hi again,
                Is it possible to share the power cycle of the schematic ? sinice i did not find out the component now i wanted to go and check its power blocks
                or if someone else has any other suggestion ?
                  dear friends I need a r Boardview for ASUS ZenBook UX3404
                  Thanks a lot.
