HP16 DAG3MMB3AAO REV A SCHEMATIC/BOARDVIEW
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    MODELl:HP 16-D0320TX(victus series)
    M/B: DAG3MMB3AAO REV A
    Boardview/schematic needed.
    • 21662
    There`s a Quanta G3MQ posted,don`t know if that will help -> https://www.badcaps.net/forum/troubl...mq-or-g3p-g3pp
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      @smdflea,no luck with the linked diagram. Mine is with separate PCH and almost nothing matches with G3MQ design.
      • madjid911
        • 408
        • France
        Hello, I have the same model with a short on the power supply, it comes from the PD8200 diode, I removed it and everything works perfectly again, the customer is quite eager to get the laptop back, I would like to know if it is really necessary to replace this diode, or can I not replace it? Because I don't have one and the delivery for the order is quite long, thank you
        • leovalpo
          • May 2014
          • 18
          • chile
          Click image for larger version  Name:	image.png Views:	105 Size:	131.6 KB ID:	3504787
          It is a protection diode, you should leave it installed to avoid future failures due to potential differences generated in that circuit.
          600 W unidirectional Transient Voltage Suppressor (TVS) in a SOD128 small and flat lead
          Surface-Mounted Device (SMD) plastic package, designed for transient overvoltage
          protection.​
          • yogova9
            • Jul 2023
            • 16
            • Chile
            I leave this boardview, it helped me for future references.
            • PacoGT
              HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
              by PacoGT
              hello firends
              i search the schematic or boardview
              I have this motherboard, but I can't find the schematic or the boardview.
              The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
              So the computer doesn't turn on, and the 3V disappears after a few seconds.
              The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
              The new problem arose after removing the bad chip.
              3V and 5V remained together,...
              08-19-2025, 08:25 PM
            • hosain0489
              Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
              by hosain0489
              I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
              Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
              If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
              Thank you very much in advance!
              07-15-2025, 11:20 AM
            • re-atari
              Gigabyte GA-H110-D3A schematic/boardview needed
              by re-atari
              Hello all,
              Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
              This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
              02-24-2025, 06:45 PM
            • jonyhdtv
              HP ProBook X360 11 G3 ee (winbook) schematic and boardview thanks
              by jonyhdtv
              Looking for schematic and boardview
              Model: HP ProBook X360 11 G3 EE
              Serial: SCG9114JG7
              Motherboard: L43774-601
              defect: touchscreen doesn't work (touch works on another computer)
              thanks to all​
              01-29-2025, 08:16 AM
            • jonyhdtv
              HP ProBook X360 11 G5 ee schematic and boardview thanks
              by jonyhdtv
              HP ProBook X360 11 G5 ee (winbook) schematic and boardview thanks
              Model: HP ProBook X360 11 G5 EE
              Serial: SCG0164QLH
              Motherboard: L83950-601
              defect: no POWER
              thanks to all​
              01-29-2025, 08:11 AM
