I have this board which has several sectors with moisture damage and I am lost without the schematics.
					help need shemantic and bordview file CT4SVC1_MB_V1.2
			by m1ch43lzmHi everyone
 I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
 Programmer models: XGecu TL866II Plus / T48 / T56 / T76
 Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
 There's also an extra OTP Secu.R...-
							Channel: BIOS Requests ONLY!
			by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
 I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
 This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
 I have opened the laptop and identified the main BIOS chip...2 Photos-
			by ahmedtouHi everyone,
 help me please
 I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
 When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
 I will share all the details with you, including the disc information.
 ...Code:HL-DT-ST BD-RE GGW-H20N XA02 (ATA) Current Profile: BD-R Disc Information: Status: Empty State of Last Session: Empty Erasable: No Free Sectors: 12,219,392 Free Space: 25,025,314,816 bytes Free Time: 2715:27:17 (MM:SS:FF) Next -
			by Forest79Hello,
 However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
			by CityminHi all,
 S/N : 5RNK9FFT70...-
- Loading...
