Need schematic HP dv6000 Daoat1mb8h0
  • lezsimply
    The Wanderer
    • 645
    • Philippines
    Hello guys, do you have diagram for this laptop motherboard Daoat1mb8h0, it came from HP dv6000 amd version. Can't see sub model from bottom case the sticker is missing.
    Problem is some component burnt. Thanks a lot!
  • bluestone
    • Jun 2011
    • 343
    • Ghana
    Re: Need schematic HP dv6000 Daoat1mb8h0
    here u go
    • lezsimply
      The Wanderer
      • 645
      • Philippines
      Thank you very much bluestone for a quick reply
      PQ32 and PQ31 got burned, maybe because of faulty adapter which is over voltage. I'll update soon and hope its good.
      • lezsimply
        The Wanderer
        • 645
        • Philippines
        Oh I just notice now its for Intel CPU, mine is AMD version. Do you have one? Thanks again
        • cyberhack
          • Feb 2013
          • 466
          • Uk
          here
          • bluestone
            • Jun 2011
            • 343
            • Ghana
            Try this
            • lezsimply
              The Wanderer
              • 645
              • Philippines
              Thank you very much guys! correct one is from post #5 1st schem. I never thought that dv6000 had a lot of versions
              I already replaced q31 and q32. laptop still dead I'm now checking surrounding component if there's fault. motherboard receives power. update you guys later
              thanks again
              • lezsimply
                The Wanderer
                • 645
                • Philippines
                Already fixed the problem regarding no power, a lot of components were replaced due to short and crack. pq31, pq32, pd17, pl8, pl5, pq3 and pc28. I also replaced pq30 and pl2. Wide are was almost covered with dark substance.
                This was cause by a faulty adapter which is over voltage. I also fixed charger. with faulty transistors. Laptop is already with the owner. Thank you very much again!
