Asus L200H - Diagram Main board E200HA Rev 2.5
  • Th3On3
    • Nov 2023
    Hello! Could someone please help me with the diagram for Asus L200H?
    YAML 19
    E11413994V-0
    I want to identify the Bios chip because requires user password when turning on. Bought it from thrift shop.
    Thank you!
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
  • ygorsan
    by ygorsan
    🧩 Problem Summary:
    • I
    07-28-2025, 08:34 AM
  • jb_Bak
    by jb_Bak
    CN6401
    Pin 01 NC
    Pin 02 NC
    Pin 03 "BL_ON": 0V
    Pin 04 "N/C"
    Pin 05 "STBY 3.3V": 3.5V
    Pin 06 "GND": N/C
    Pin 07 "AC_OFF"...
    09-27-2021, 04:52 PM
  • JDC
    by JDC
    ONN 100012588
    Long answer:
    07-15-2022, 07:39 AM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
