Aspire 4736z KALG1 schematics
  • salawayon
    • Nov 2012
    • 569
    • philippines
    Any one could share the schematics of KALG1 LA-5272P? Unit is totally dead... Tried already replacing ENE and isl6237... Switch voltage is always at 19vdc.
    Thanks....
  • jtamad44
    • Apr 2013
    • 145
    • israel
    Re: Aspire 4736z KALG1 schematics
    try to flash the bios.
    • PlusCom
      • May 2013
      • 50
      • Greece
      Schematics.
      • salawayon
        • Nov 2012
        • 569
        • philippines
        Is it possible due to bios problem why it is totally dead? I'm concerned with the supply voltage at the power switch that instead of 3.3vdc i got 19vdc. Which is not normal for me.
        Thanks for the schematics.
        • Francisco.s
          • 686
          • Spain
          High voltage in power switch, is perfectly normal. It comes from PQ1 (page 37) trough its internal diode, and PR12/ PR13, reaching the 51ON# point.
          Check pin 8 voltage of U13 (bios chip) in order to know if there is +3VALW.
          • salawayon
            • Nov 2012
            • 569
            • philippines
            Thanks for the info.... BTW, is +3VALW is same with +3VALWP? I'm just a bit confused with the power up sequence of laptop computers. Just really wanted to know everything why it became dead. Because at some brands i always got 3.3vdc at power switch line.
            • Francisco.s
              • 686
              • Spain
              Yes, +3VALW is the same as +3VALWP, they are joined by PJ2. (JUMP_43X118)
              You can cut down pj2, in order to isolate both voltages.
              • salawayon
                • Nov 2012
                • 569
                • philippines
                When it will became 3.3vdc at switch line, after pressing the switch when everything is ok?or it will always be at 19vdc during standby?
                • salawayon
                  • Nov 2012
                  • 569
                  • philippines
                  Found it (PJ2) at p37. Maybe i'm dealing with same problem with lenovo g475 they got same schematics.
                  • Francisco.s
                    • 686
                    • Spain
                    +3VALWP should be there as soon as you connect ac adapter, and signal MAINPWON go to high level, and if PU4 is not damaged.
                    • salawayon
                      • Nov 2012
                      • 569
                      • philippines
                      No voltage is present at all pins of U13... Even +3VALWP at PU4 not present.... Tried already replacing PU4 but still the same.
                      • Francisco.s
                        • 686
                        • Spain
                        Check 19volts at pin 6 of PU4, PR35 could be open.
                        • salawayon
                          • Nov 2012
                          • 569
                          • philippines
                          19vdc at pin6 of PU4 is measurable. Do i have to replace again the PU4?
                          • bowor
                            • Oct 2013
                            • 36
                            • indonesia
                            I'm trying to add. if no voltage 3/5valw of: ic power, embedded controller (ec), sb chipset, vga.
                            • whaldsz
                              • Apr 2013
                              • 395
                              • Philippines
                              You have 19v right? now, Check the voltage of pin 1, 7, 4, 14, 27 of PU4.
                                ACER Aspire Aspire X3910 Aspire E5700 Specification for Upgrade or Repair
                                This specification for the ACER Aspire Aspire X3910 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X3910 boardview and Aspire Aspire X3910 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                09-12-2024, 03:36 PM
                                ACER Aspire Aspire XC-330 Aspire XC A4-9120e Specification for Upgrade or Repair
                                This specification for the ACER Aspire Aspire XC-330 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-330 boardview and Aspire Aspire XC-330 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                09-12-2024, 03:30 PM
                                ACER Aspire Aspire XC-886 Aspire XC i5-9400 Specification for Upgrade or Repair
                                This specification for the ACER Aspire Aspire XC-886 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-886 boardview and Aspire Aspire XC-886 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                ACER Aspire Aspire XC-780 I6608 BE Aspire XC i5-7400 Specification for Upgrade or Repair
                                This specification for the ACER Aspire Aspire XC-780 I6608 BE can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-780 I6608 BE boardview and Aspire Aspire XC-780 I6608 BE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                09-12-2024, 03:28 PM
                                ACER Aspire Aspire TC-885 I5618 BE Aspire TC i5-8400 Specification for Upgrade or Repair
                                This specification for the ACER Aspire Aspire TC-885 I5618 BE can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire TC-885 I5618 BE boardview and Aspire Aspire TC-885 I5618 BE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
