IC charger HP DAG7BMB16E0 REV E
  • kto1983
    • Jul 2016
    • 10
    • chile
    Hello guys, I need your help, I have a HP DAG7BMB16E0 REV E motherboard without a charging ic, I do not have a schematic or boardview, thank you very much.
    Any information about this model is good since I do not have brd, pdf or bios
  • AL._.EX
    • Dec 2022
    • 896
    • Belarus
    Re: IC charger HP DAG7BMB16E0 REV E
    • kto1983
      • Jul 2016
      • 10
      • chile
      Muchas gracias buen hombre!!!
      • motormayhem
        Lenovo T460 Only Charges on One Charger
        by motormayhem
        Laptop Question
        I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
        A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
        05-12-2023, 01:46 PM
        NVDC charger configuration...
        11-05-2024, 03:28 PM
      • flat-earther
        how to prevent a connected charger from draining battery when not charging?
        by flat-earther
        I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
        So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
        but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
        So the battery is backfeeding the charger and being drained.
        How can I prevent...
        08-07-2025, 01:04 PM
      • flat-earther
        ASUS X54H laptop thinks it's always charging even with charger unplugged
        by flat-earther
        The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
        Windows also shows ''Plugged in'' when charger is not connected.
        This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
        Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
        If I let battery run out and say it has 3% Windows will...
        06-24-2025, 09:32 AM
      • Johndill
        Dell Inspiron 7567 LA-D993P odd charger issue
        by Johndill
        Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
        There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
        I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
        Here are the tested scenarios:
        1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
        2. With the laptop off, plug in charger (LED says on) & the front charging...
        11-16-2022, 10:55 PM
