need nm-c561 images
  • ahmarzo
    • Mar 2015
    • 168
    • india
    need nm-c561 images
    have motherboard gs44b/nm-c561 v 1.0 need hd images as some components are missing.plz anyone have the board or images plz provide me clear top and bottom images.
  • rediii
    h???, spurrrn
    • Mar 2018
    • 485
    • somewhere in europe
    Re: need nm-c561 images
    here: schematic and boardview
    https://www.badcaps.net/forum/showth...hlight=nm-c561
    • bfrobro
      Ericsson R380s firmware images?
      by bfrobro
      Hi all!
      I have two old Ericsson R380s phones that likely have corrupted memory. One doesn't charge and doesn't boot at all. The other boots but crashes within 30 seconds or so, and sometimes suggests a system format but does not proceed with that.
      Does anyone know if there are firmware images available for this phone? I should already have a cable and software for reflashing the firmware, but not the actual firmware images. Based on some old information, there should be three files ("phone", "pda", and "eeprom") but I'm not sure about th...
      06-09-2025, 12:43 PM
    • Rozp
      70LE660U dark cloud or black screen with sound.
      by Rozp
      Hello Everyone,
      This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
      I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
      08-29-2023, 05:25 PM
    • davidebaldini
      ATX power supply keeps blowing PFC mosfets — Cooler Master RS-550-ACAA-E3
      by davidebaldini
      This is an ATX PSU rated for 550W powering 24/7 a computer load of about 200W, fed by a line-interactive 1500VA UPS. Mains is 230V.
      1. First issue: the PSU blew a mosfet on what I think is the active PFC boost converter, shorting its G D S pins together causing a short across the + and - lines produced by the rectifier on the 230V mains. The surge protector of the house tripped. When this happened I found that the UPS was unexpectedly disconnected from the wires of its battery. The UPS wasn't damaged, but I suspect this spontaneous detachment of a battery wire caused a condition that blew
      01-25-2023, 02:23 PM
    • randmusr
      Internal images saved here have disappeared
      by randmusr
      Is there a time limit to when / how images uploaded to the internal server are governed?
      My uploads from around December last year are gone? Is badcaps forum going under?
      06-18-2025, 05:00 PM
    • arctor
      LG 55uh661v flickering images and lines
      by arctor
      Hi, I have this tv a LG 55UH661V that show flickering images and lines. I tried to take off one at time the right and the left ribbon cable and put the tape for ask the pin…but nothing working. Or I stop to have picture or still flickering. Someone can help me to understand what pin I have to mask? What I notice the buffering board, the flat cable becomes very hot, I don’t think it s normal, I’m talking about the orange flat cable soldering on the buffering board, both side are very hot. I give you the photo with both the ribbon cable on and a photo with the right off and with the lefts...
      06-16-2025, 11:57 AM
