HP Zbook 14 G8
  • electroelef
    • Jun 2014
    • 57
    HP Zbook 14 G8
    Hi
    I am looking for a schematic diagram and ideally board view for HP Zbook 14 G8.
    Anybody can help?
    The main reason is that I found a MOSFET IC shorted on the board. The code written on it is MPMP 2941 and I need to identify it so I can order one.
  • AL._.EX
    • Dec 2022
    • 896
    • Belarus
    Re: HP Zbook 14 G8
    Platform???
    • electroelef
      • Jun 2014
      • 57
      Re: HP Zbook 14 G8
      the platform is Intel
        • 21886
        Re: HP Zbook 14 G8
        Post the motherboard model number
        Beginner's guidelines - https://www.badcaps.net/forum/showthread.php?t=88758
        1.1.3 Motherboard model number
        • AL._.EX
          • Dec 2022
          • 896
          • Belarus
          Re: HP Zbook 14 G8
          Platform it - Asus, Apple, Compal, LCFC, Inventec, HuaQuin, Quanta, Wistron, Pegatron, Bitland, Foxconn, 3nod, Samsung, TongFang.........
          • electroelef
            • Jun 2014
            • 57
            Re: HP Zbook 14 G8
            So sorry.
            The motherboard model is:
            CM-4 94V-0
            CORVETTE-6050A3213301-MB-A01(A1)
            Can't find any other codes on the board.
            To be honest even if I would get my hands on a slightly diferent model of motherboard from the same series (if that exists) there is a good chance that the MOSFET IC used on mine will be used on that as well.
              • 21886
              Re: HP Zbook 14 G8
              So sorry.
              CM-4 94V-0
              Are you sure its a mosfet. Post a picture of the IC with the part number on top,and another with it desoldered so that we can see how many pins it has underneath.
              It could be Monolithic Power MP2941 ? ,there`s no datasheet available but found the part in some other schematics
              NM-C761 https://www.badcaps.net/forum/showthread.php?t=113193 MP2941
              LA-J551P https://www.badcaps.net/forum/showthread.php?t=97516 MP2941BGL-Z_QFN19_3X4
              https://www.ebay.com/itm/403412936847
              https://www.aliexpress.com/item/1005003166990987.html
              • electroelef
                • Jun 2014
                • 57
                Re: HP Zbook 14 G8
                Thank you so much for the time spent helping me.
                MP2941 seems to be exactly it.
                It looks the same as the one I took out from the board.
                I tried to start the board without it and it does work without the dedicated GPU. Only Intel is on which is quite normal I think.
                I will buy one and see how is going. I hope the GPU chip is working fine.
                Thank you again so much for your help
                • konare
                  • Aug 2022
                  • 43
                  • Mali
                  hi,
                  I am looking for a schematic for HP ZBOOK 14 G8 CORVETTE-6050A3213301-MB A01(A1). The main reason is that the machine turns on and makes 3 long beeps and 2 short beeps. I checked this on their site and it means a Ram problem, the motherboard has an integrated Ram, and I want to remove the 1 strip see if it works and otherwise I delete the second one too and restart the first one
                  Can someone please help me? Thanks in advance​
