Asus UM433D - UX434DA boardview and schematics
  • orion78fr
    • Apr 2022
    • 37
    • France
    Hi !
    Do anyone have boardview and schematics for the Asus motherboard UX434DA for the laptop UM433D ?
    I need them because I'm going to try to bypass bios password by shorting the SCL and SDA pins while the BIOS checks the password as told in this article : https://davidzou.com/articles/bios-password-bypass
    I can't find any way to recover password (alt+r while prompted for password doesn't work). If you know any other way to bypass the bios password, I'll gladly take it.
    If nobody have these, can someone tell me which chip is the bios on this board ? Is it the gigadevice GD25LB64C, as I'm guessing ?
    Thanks a lot !
    • 21936
    Re: Asus UM433D - UX434DA
    Originally posted by orion78fr
    Hi !
    Thanks a lot !
    You can`t short the bios chip on this board to remove the password, you could even damage the chip or brick the motherboard. The article shows a small chip with the name L08 on it, that chip is installed on some lenovo motherboards.
    Make a backup of the GD25LB64C chip and post it in the laptop "Bios requests ONLY!" sub forum -> https://www.badcaps.net/forum/forumdisplay.php?f=40 and someone will fix it for you
    • orion78fr
      • Apr 2022
      • 37
      • France
      Well, I don't know what to say, I tried it anyway before you answered the thread and it worked.
      I successfully glitched the bios password read to a null (I guess ?) after a few tries and then changed it after in bios options.
      Anyway, I couldn't find the boardview & schematics anywhere, so if anyone have it, it'll be useful for the next person that need it.
      • anshad
        • Nov 2010
        • 249
        That doesn't make any sense. What you short in ThinkPad laptops is not the BIOS chip but a security EEPROM chip. By shorting the chip, you are essentially preventing the BIOS from reading the chip and hence the hack works. In your case, the chip you were referring is a BIOS chip. Shorting it's pins should have prevented the system from reading the BIOS code and one should expect no POST as a result. Shorting the BIOS chip prevented the system from exclusively reading the password part but has no problem reading the rest of the BIOS code and generate display ?
        • orion78fr
          • Apr 2022
          • 37
          • France
          So, I had a button soldered between pins 5 & 6. If I shorted too early in the boot process, I got no POST, obviously. If I shorted too late, I got the password prompt. But one time, I saw the bios screen. I probably successfully shorted the two pins just after the boot sequence and just before the bios password read by the CPU ? I don't really know. Took ~ 20 tries to get the correct timing. All I know is that I got rid of this annoying password and the computer works...
          • alltvrepairs
            • Jan 2014
            • 252
            • Malta
            Asus Zenbook 14 UM433D main board and/or schematics
            I have been donated this Notebook. The battery connector was broken by owner. I have tried to resolder direclty to main board worked fine but accidentally a piece of copper fall on the board near the supply charging connector and switched off. Tried with the multimeter for possible shorts or evident damage but could not find any obvious.
            Any help pls or someone having a replacement main board at a reasonable price?
            Tks
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              Re: Asus Zenbook 14 UM433D main board and/or schematics
              Tks
              This is "Schematic Requests ONLY" sub-section, if you want help beyond a shematic request you can open a thread at the Tech section:
              https://www.badcaps.net/forum/forumdisplay.php?f=23
              "Looking To Buy" sub-forum is here:
              https://www.badcaps.net/forum/forumdisplay.php?f=13
              Read the rules.
              Become a Badcaps supporter
              Thanks to all supporters.​
              • pirati
                by pirati
                10-27-2025, 04:20 PM
              • grimacelord
                by grimacelord
                07-10-2025, 02:52 PM
              • snpetit
                Asus FA706IH Bios Password remove
                by snpetit
                i need some help :-/
                i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
                Could you please remove all password related stuff from this bios. A hate Asus....
                Thanks in advance!...
                01-10-2025, 09:17 AM
              • ArkzG
                [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                by ArkzG
                Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                What I currently have available:
                - Model: FA506NF (2021)
                - BIOS chip: GD25LQ16 (16Mbit/2MB)
                - Tools: CH341A programmer ready to use
                Does anyone have either a clean 2MB .bin dump of this model,...
                09-26-2025, 09:34 PM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
