Need bios for Lenovo Ideapad 330s-15IKB GTX1050
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3586
    • slovakia
    board marking is 330s-MaxP_MB_V04
    I attach original bios and bios update from lenovo fom i cannot extract bios
  • hoaca388
    Badcaps
    • Jan 2022
    • 11700
    Re: Need bios for Lenovo Ideapad 330s-15IKB GTX1050
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3586
      • slovakia
      thanks mate
        • 20792
        You can extract the exe using innoextract ,then open with a hex editor, search for the word BIOSIMG .The start off-set is on the line below at 96010 , choose "select block" with that start off-set, then 800,000 as the file length.As you know 800000 in hex is 8MB, you`ll know its the right end off-set as it`ll have the word "$_IFLASH" after it on the line below.Copy to a new file and save it.
        Your DMI is at 200000 - 20022F and 5E0000 - 5E003F
        Alternatively you could try extracting with Insyde iFlash/iFdPacker Extractor .I havnt tried it yet so i don`t know how well it works.
        https://www.badcaps.net/forum/showpo...45&postcount=7
        • mximiliandz
          help bios lenovo ideapad s145-14iil type 81w6
          by mximiliandz
          Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
          06-20-2025, 06:50 AM
        • jendkkd jeje
          Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
          by jendkkd jeje
          So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
          I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
          10-11-2024, 03:12 PM
        • Wahaz
          by Wahaz
          10-30-2023, 08:42 PM
        • grimacelord
          by grimacelord
          Hello there.
          History:
          03-15-2023, 03:29 PM
        • Popel1083
          Lenovo IdeaPad U330p Read Bios than Bios Password Remove
          by Popel1083
          I want to remove the Bios Password of my Lenovo IdeaPad U330p with the Lenovo autopatcher. I have the CH341A Black and I'm using NeoProgrammer. The Programmer has an LED that indecates when it reads or writes the Chip. When I try to Connect my Programmer to the Bios Chip (Winbond 25Q64FVSIQ) the LED lights up even though I didn't click on Detect botton in NeoProgrammer. If i click on Detect the LED still remains on and NeoProgrammer says "IC not responding".
          SN: QB08570065
          MB: DA0LZ5MB8D0; REV: D; MODEL J31/N02
          08-06-2024, 05:52 PM
