Hp zbook g5 bios and ec needed
  • Marpolex
    • Aug 2021
    • 14
    • Polska
    Hi, does anyone has a working bios(32MB) and ec dump to hp zbook 17 g5 ?
  • hardware1
    • Sep 2021
    • 2951
    • N/A
    Re: Hp zbook g5 bios and ec needed
    Upload your original backup files.
    all donations are welcome,
    • Marpolex
      • Aug 2021
      • 14
      • Polska
      It's corrupted.
      • hardware1
        • Sep 2021
        • 2951
        • N/A
        It's corrupted.
        Try this file with your 32MB chip and put your 16MB chip back.
        • Marpolex
          • Aug 2021
          • 14
          • Polska
          Did not work
          • hardware1
            • Sep 2021
            • 2951
            • N/A
            Did not work
            What was your main problem?
            With my file the device symptoms are different or the same?
            • Marpolex
              • Aug 2021
              • 14
              • Polska
              Laptop died after bios update. Turns on with fans 100% and no display. I have tried with working bios file and my ec it starts and works fine under windows until i shut it down. After shutdown it has problem to start again u need to push power button multiple time and not always powers on.
              • YKMN
                • Dec 2022
                • 29
                • NL
                If he responds go to Bios and try do the Bios update once again if you didnt try it yet.
                Is that Bios dump you made before or after Bios update ?
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12441
                  Try
                  • Marpolex
                    • Aug 2021
                    • 14
                    • Polska
                    If i update bios it dies again. Dump after bios update (corrupted)
                    • Marpolex
                      • Aug 2021
                      • 14
                      • Polska
                      Originally posted by hoaca388
                      Try
                      Did not work, no reaction to power button.
                      • YKMN
                        • Dec 2022
                        • 29
                        • NL
                        Ok, try this old vers. of Bios if its gonna work update to newest one.
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12441
                          Try again
                          • Marpolex
                            • Aug 2021
                            • 14
                            • Polska
                            Works ! Thanks
                            • DynaxSC
                              by DynaxSC
                              11-17-2023, 10:56 AM
                            • TacticalFahrrad
                              [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                              by TacticalFahrrad
                              I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                              BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                              I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                              06-30-2025, 04:09 AM
                            • zlr8r
                              Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
                              by zlr8r
                              Greetings
                              I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
                              Serial Number: 5CG3202C16
                              Product #/SKU: 739P0AV
                              CT Number: PRTUE00WBI30YX
                              Description: HP ZBook Firefly 14 inch G10
                              BuildID: 23WWWGAZ602#SABU#DABU
                              Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
                              MAC address not found.
                              • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
                              10-28-2025, 01:56 PM
                            • vinaypundith
                              Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                              by vinaypundith
                              I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                              So, I'm looking for a BIOS dump for this machine - a 16MB one....
                              08-03-2024, 12:32 PM
                            • James Maxwell
                              HP DM1-4000er Bios Dump needed
                              by James Maxwell
                              I badly need bios dump for HP DM1-4000er,
                              Model: HP DM1-4000er
                              Motherboard: DA0NM9MB6D0 REV.D
                              Product: QJ490EA#ACB
                              Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
                              10-28-2024, 05:38 PM
