Latitude 7430 bios
  • Markus1741
    • Sep 2020
    • 843
    • N/A
    #61
    Originally posted by vuquanghoanh
    Thank you for unlocking this bios dump.
    I have loaded the bios chip but there are some problems.
    1. CPU fan is always spinning.
    2. The device does not receive wifi
    3. The keyboard makes a "Beeep" sound when I press any key.
    Please help me one more time. Thank you​
    Hello, watch this short video and follow what Vesko356 wrote to you then it should work, good luck with it.
    https://www.youtube.com/watch?v=3AJxkT1cLdQ
    • vuquanghoanh
      • Feb 2023
      • 45
      • US
      #62
      You are correct. I haven't exited Manufacture mode yet. Thank you very much.
      • vuquanghoanh
        • Feb 2023
        • 45
        • US
        #63
        Thank you.
        After following your instructions, my laptop is almost normal. Now there is a wifi problem, I tried installing the wifi driver but it didn't work. Have you encountered this error before?
        Best,​
        • vuquanghoanh
          • Feb 2023
          • 45
          • US
          #64
          I went to the Dell support homepage and downloaded the driver, the laptop worked normally.​
          • danish8717
            • Dec 2021
            • 26
            • united arab emirates
            #65
            dell 7430 bios + logo change
            ST-5VFP5X3
            • Vesko356
              Vesko356 commented
              Editing a comment
              Read the rules before posting:
              You MUST
              • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
            • danish8717
              danish8717 commented
              Editing a comment
              Sorry for the mistake i will be careful next time
          • danish8717
            • Dec 2021
            • 26
            #66
            inside bios password or not dell logo coming
            • andrew25
              • Feb 2016
              • 222
              • Malawi
              #67
              can anybody please help me unlocking my dump...
              LA-L581P.
              Service Tag: BP71TQ3
              • Markus1741
                • Sep 2020
                • 843
                • N/A
                #68
                LA-L581P.
                Try ...
                Important: Input the Service Tag, save the settings, and then restart and press Alt+F to exit manufacturing mode.
                • andrew25
                  • Feb 2016
                  • 222
                  • Malawi
                  #69
                  Try ...
                  thanks bro, it worked okay
                  • ctebke
                    • Sep 2014
                    • 36
                    • Serbia
                    #70
                    Hello, I need help with removing BIOS password. Thanks....
                    LATITUDE 7430
                    Service Tag: 7DQ3TQ3​
                    • Markus1741
                      • Sep 2020
                      • 843
                      • N/A
                      #71
                      LATITUDE 7430
                      unlocked ....
                      • ctebke
                        • Sep 2014
                        • 36
                        • Serbia
                        #72
                        Works perfect, THANKS 😃
                        • djtaotao
                          • Nov 2023
                          • 22
                          • Sweden
                          #73
                          can anyone please check for me if the attached bios is not corrupted?
                          Dell Latitude 7430
                          ST: GRBPJR3
                          Thanks in advance!
                          • Vesko356
                            Vesko356 commented
                            Editing a comment
                            Thread merged.
                            Read the rules please
                            You MUST:
                            • Post under a related thread if it exists
                        • djtaotao
                          • Nov 2023
                          • 22
                          • Sweden
                          #74
                          Hello again,
                          I come back with my problem.
                          Please help me with bios clean ME.
                          This time I attached both bios files.
                          Dell Latitude 7430 - not powering on, not charging.
                          The USB charger is negotiating the voltage and the USB meter shows 19.98V and 0.08A on both ports.
                          When I plug in the charger the led on the power button lights up and stays on for 30s, turns off for 1s and turns on again for 30s and so on.
                          3.3V and 5V are present.​
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11787
                            #75
                            Originally posted by djtaotao
                            Hello again,
                            Latitude 7430
                            Service Tag: GRBPJR3
                            • djtaotao
                              • Nov 2023
                              • 22
                              • Sweden
                              #76
                              Originally posted by hoaca388
                              Latitude 7430
                              is this a cleaned ME file? I noticed this is only the 32MB bios file, should I use the old-unchanged bios 16MB file?
                              Thanks!
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11787
                                #77
                                Thanks!
                                The 16MB file is an ME file, which cannot be cleaned.
                                • djtaotao
                                  • Nov 2023
                                  • 22
                                  • Sweden
                                  #78
                                  Then what should I do with the file you upload it?
                                  • farouk_1994
                                    • Mar 2021
                                    • 392
                                    • algeria
                                    #79
                                    DELL latitude 7430 bios corrupted need clean me if someone can do it please .
                                    S/T: 7872TQ3
                                    MB: LA-L581P
                                      SMDFlea commented
                                      Editing a comment
                                      Thread merged.Why start a new thread ? ,use forum search to find related topics where you can post your request !
                                  • mac2sell
                                    • Aug 2017
                                    • 64
                                    • Italy
                                    #80
                                    Dell_7430_locked.rar Please help me to unlock dell 7430
                                    Service tag: JG96VT3
                                    • macabook
                                      by macabook
                                      🧩 Initial Issue
                                      07-24-2025, 02:17 PM
                                    • gizaha
                                      by gizaha
                                      02-13-2024, 07:18 AM
                                      DELL Latitude 7430 Notebook 7000 Specification for Upgrade or Repair
                                      This specification for the DELL Latitude 7430 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7430 boardview and 7430 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7430...
                                      09-07-2024, 07:19 AM
                                      09-07-2024, 06:31 AM
                                    • grimacelord
                                      Latitude E6530 - Trouble Extracting BIOS Image From EXE
                                      by grimacelord
                                      Hi folks,
                                      I'm having a hard time extracting this Dell BIOS. I have a Dell Latitude E6530 that has BIOS corruption and I need to reflash with CH341A programmer. I have already taken dumps of both the 4MB and 8MB chips on the motherboard.
                                      Service tag number for this model is: "JYDWYW1".
                                      Link to latest BIOS for this Service Tag: https://dl.dell.com/FOLDER05371360M/1/E6530A22.exe
                                      I have tried:
                                      • Simply extracting with 7zip
                                      • PFSExtractor
                                      • Using "/writeromfile, /writehdrfile, and /writehexfile" commands
                                      • Check Temp folder
                                      10-26-2023, 08:15 AM
