Latitude 7430 bios
    Re: Latitude 7430 bios
    Originally posted by santoslao View Post
    Please help me with removing BIOS password from the attached dump
    Thanks!
    Hi Test and comments
      Help me to unlock dell 7430
        Originally posted by ramkaskad12 View Post
        help me to unlock dell 7430
        try
          Originally posted by qayyum786 View Post
          try
          it worked thanks
            The only solution is to cut vcc tracks from the bios chip 256.
            So you need to cut motherboard or remove the chip? No way to do elsewhere without physical damage?
              this is just an option, but there is no other way than to remove the chip and use an adapter.
                Thanks. I think there is no other way to read out chip by cable on circuit like before. I had the same experience with other 12gen latitude models like 5430,5431 and 7430. Unable to read and erase correctly on circuit.
                  unfortunately these new models cannot, you are forced to remove the chip from its place or make a cut in the VCC track of the chip.
                    Help I have computrace active I need to deactivate HELP PLEASE
                    Servise tag:421vpn3
                      Servise tag:421vpn3
                      computrace is on the other chip!
                        here is the second bios chip
                        help remove computerace please thank you
                          Plz i need help to know the Dell latitude 7430 bios chip ,i see 3 of them see att
                            It's the biggest chip.
                                Read the rules before posting:
                                Become a Badcaps supporter
                                Thanks to all supporters.​
                                  OK
                                  LATITUDE 7430
                                  ST 1RYTW3
                                    Originally posted by mazmaz23 View Post
                                    ok
                                    please help me with removing bios password from the attached dump
                                    latitude 7430
                                    st 1rytw3
                                    st 1rytw3
                                      it worked thanks
                                        plz need unlock this one
                                          Hello i will try to help you but first we need your Service Tag its a Rule hear ....
