Acer TPM658-M-58X3 BIOS unlock
  • OntarioTL
    • Feb 2022
    • 55
    I guess this laptop is under the new algorithm for the 8 digit key unlock. I've tried both websites (https://www.biosbug.com/acer/ and https://bios-pw.org/) with no luck.
    Here is the BIOS backup file. I hope someone can clean the password off of it.
    I tried looking through UEFItool and hexeditor with no luck finding it.
    Even if someone has the new algorithm unlocker by chance. The code I got was 51290853.
    Thanks in advanced.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12278
    Re: Acer TPM658-M-58X3 BIOS unlock
    Originally posted by ontariotl
    i guess this laptop is under the new algorithm for the 8 digit key unlock. I've tried both websites (https://www.biosbug.com/acer/ and https://bios-pw.org/) with no luck.
    Here is the bios backup file. I hope someone can clean the password off of it.
    I tried looking through uefitool and hexeditor with no luck finding it.
    Even if someone has the new algorithm unlocker by chance. The code i got was 51290853.
    Thanks in advanced.
    try
    • OntarioTL
      • Feb 2022
      • 55
      Thank you very much! Worked like a charm.
      I had a look with a hex comparator and found the edit with it and the address location. I would have never have found it on my own. I'll keep this in mind if I happen to run into this issue again with this model.
      • zenius
        by zenius
        12-08-2024, 06:13 AM
      • EbrahimSiami
        Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
        by EbrahimSiami
        I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
        **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
        **What I have tried so far:**
        1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
        07-02-2025, 02:31 PM
      • Wg188
        ACER Veriton Z4660G AIO bios help
        by Wg188
        I have an Acer veriton Z4660G all in one pc,
        Model: Z4660G-I5850H1 (VZ4660G_W)
        Need bios dump and schematic would save my life !
        to make a long story short I bought this all in one used
        with a broken lcd, with the objective of making a custom desktop out of it
        ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
        06-17-2023, 02:20 PM
      • bf3itu
        Unlock Bios Acer Chromebook R721T-488H
        by bf3itu
        Need unlocked Bios for Acer Chromebook R721T-488H
        HI EVERYONE I have Stuck for This Acer Laptop, I Need Unlocked Bios For the Mentioned Model. Any Hell Will Be Highly Appreciated.
        Thank you very much​
        Model:N18Q12
        DAOZADMB8H1 REV:H
        AMD...
        04-29-2025, 08:29 AM
      • macabook
        by macabook
        🧩 Initial Issue
        07-24-2025, 02:17 PM
